Delay Windshield Wipers
Living here in the wet coast has got me wondering whether there is a upgrade to delay style windshield wipers. Anybody have any leads?
Toys: 72 K5 Blazer 74 Vette |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
There was a thread some time ago about someone adapting a int. wiper switch from a GM school bus.
It was at least 1.5 yrs ago though.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
SKINNY TIRES RULE!
I've always wondered why one of the aftermarket companies hasn't come out with a kit that will work in the original switch position. I would use it a lot!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
They (aftermarket variable speed wiper) used to be available from JC Whitney and other el cheepo parts places. Might try some older auto parts stores in your area. It wires into your motor and has a small slide switch mounted under the dash. I have one around someplace that I plan on using some day.
go cyclones
here is the directions in the FAQ section
http://67-72chevytrucks.com/vboard/s...ht=delay+wiper |
collector of vintage rust
I used to work on school busses. The switches will vary by body type(thomas,bluebird,carpenter,etc.)not chassis........that is a good idea though!
wiper delay
I have used Chevette delay relays and controls. Chevettes have a rectangular wiper motor like the trucks and pull and twist knob mounted on the dash below the headlight switch. The Chevette wiper control is on the column but the delay is on the dash. There is a wiring connector where the delay is jumpered in. Only problem is finding "optioned" Chevettes in the junkyards now. The rewiring to fit the truck is quite simple. The delay control shaft is even the same diameter and shape as the truck wiper switch so I just use a P/U wiper knob.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Lovin' Life in Miss.!
Now that is a cheap junk-yard mod. Wish I would have known about that before I plunked down 50 odd bucks for the bus switch.
The truck... you hear that? No really, you did hear that?!!! |
What would it take to hook up foot switch similar to a dimmer switch-momentary on like a starter switch-for one wiper cycle at a time. For me, in newer cars, I use that option alot more than the delay. On my f*rd company truck, the wiper control is on the column and just push in on it for one wipe at a time.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
