Old 01-19-2005, 04:51 AM   #1
Jimmy Canuck
Jimmy Canuck's Avatar
Front Diff/Hub Help
Yesterday as I was wheeling in 4 high through snow coming down from the ski hill, my left hub bound up, caused the left axle to stop and sheared off all the studs.......as I watched my tire pass me. Good thing I was going slow, and the snow helped reduce the impact so not too much damage.
Any suggestions on why my left hub would bind and not allow me to turn it from lock to free, and what would cause the front diff to bind enough to shear the studs on one side?
I'm new to the world of ancient 4x4's. Thanks in advance.
Jimmy Canuck is offline   Reply With Quote
Old 01-19-2005, 12:22 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Well my guess is something broke,bent or jammed.
U-joint could have broke and jammed in the yoke.Maybe the axle got bent enough to sieze.
Hub bearings siezed?
Locking hubs broke seriously enough to jam the hub?
Check the u-joint 1st,That's easy...just look at it to see if it's broken.
Next you'll need to remove the locking hubs anyway to fix the wheel studs so you can see what,if anything,has happened to the locking hubs.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-19-2005, 12:23 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
First, welcome to the board. My wife and I were just up in BC (Vancouver) for the weekend. That is such a nice, clean city-even with the snow and slush!
Have you pulled the cover on the front diff? It could be any number of things that caused it to bind - no fluid, broken gear, bolt backing out.
Do you think the hub caused the diff to bind or vicea-versa?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-19-2005, 01:35 PM   #4
Burt4x4
Burt4x4's Avatar
Yup many things could have done it.
Sounds too me you front axel needs to be gone thru from hub to hub. Maby get a donor axel you can tear apart to see how it all works, then rebuild the one under your truck.
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-19-2005, 02:44 PM   #5
Jimmy Canuck
The u-joint is ok and I had changed the diff oil the day before, so now it is time for a teardown. Thanks for the welcome and suggestions.
Old 01-19-2005, 05:06 PM   #6
moodyholler
moodyholler's Avatar
Snow!
Did it pack up with snow around the u-joint? moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
