01-22-2005, 11:35 AM | #1 |
Active Member
NP205 gear oil capacity/type?
Just got our transfer case back from the shop,what to fill it before it goes back in.What is the capacity? Should it be 80-90 gear oil?
Thanks!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
01-22-2005, 12:48 PM | #2 |
Usually, little more than 1/2 gallon of 80-90
01-22-2005, 02:40 PM | #3 |
Active Member
Thanks Kw! Getting started on it right now.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi Last edited by Curbstone Mech; 01-22-2005 at 02:41 PM. Reason: too short |
01-22-2005, 02:59 PM | #4 |
I have dexron in my 205, is that bad? I was told you could use it. 80-90 is kinda thick at -30
01-22-2005, 03:04 PM | #5 |
Not a bad nut after all..
I've heard automatic trucks should use tranny fluid, and manual trucks should use gear lube. It seems like a good idea if there is any leakage between the two. Any truth to this?
01-22-2005, 05:21 PM | #6 |
"Ochre Ogre"
Using tranny fluid in all of mine.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
01-22-2005, 06:55 PM | #7 |
Straight out of the factory service manual "SAE 80 GL-5 Gear Lubricant". It's what I ran in mine. I've seen and heard of auto tranny fluid in T-cases but sometimes it's in there because it has leaked through the adapter.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
01-22-2005, 06:59 PM | #8 |
I forgot to mention that the NP205 is gear driven but most of the other T-cases are chain driven and I'm pretty sure that the recommened lube for them is tranny fluid. Funny thing is I can't find a quantity for the NP205 in the manual.
01-23-2005, 01:23 AM | #9 |
When I fill my NP205, I jack up the rear of the truck so I get in a little more. I use synthetic so I don't fear foaming.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
01-26-2005, 10:53 PM | #10 |
I am installing my rebuilt 350 engine and 350 tranny this weekend in the 72 GMC K20 so which is the correct fluid? I was planning on synthetic 75-90 for the 205? Does two quarts of this sound correct?
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 01-26-2005 at 10:56 PM. |
01-28-2005, 10:58 AM | #11 |
Make sure whether your tranny calls for a GL-4 or GL-5 fluid, before you fill it.
01-28-2005, 11:22 AM | #12 |
A couple of other chvey boards I frequent have had this discussion and debate quite a few times. The end result?--- The 205s are damn near indestructible. Pretty much if you have a decent quality oil in them, they will last, some oils however may let the the t-case generate more noise than others but will not 'hurt' them. If you worry about a seal breach between the trans and t-case then use matching oils. Personally I am getting ready to use another NV4500 in a truck I am building with a doubler. I'll be using the synthetic for the NV in both the 203 and 205. My understanding is if you get any other type of oil in the NV other than the required synthetic it will destroy it.
01-29-2005, 02:54 AM | #13 |
The NP205 holds 2.5 qts. prior to 1980 they had 85w90. In 80 GM switched to dextron I suspect for fuel economy. But in 80 they also redesigned the ouput shaft to a slip yoke instead of a slip shaft driveshaft I don't know if the redesign required the fluid change. In really cold weather when warming up the engine, put the transfer case in neutral and trans in high gear it will limber it up pretty quick.
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 Last edited by 687980chevy; 01-29-2005 at 02:57 AM. |
09-07-2014, 01:39 AM | #14 |
Re: NP205 gear oil capacity/type?
What if my truck is a 80 with a slip yoke? Also what is some ideas or recommandations for when the slip yoke leaks? Should a just replace the seal, replace the seal and yoke or I have heard of a conversion? There is a good amount of play back there and it is leaking kind nice.
I pity the fool with only 2 headlights! |
