Blazer VS. Truck axles
I was just wondering. Are the 4X4 Blazer Axels the same width as the 4X4 truck axels. Meaning... will Blazer axels work on a 4X4 truck?
Yes
Tim |
Thanks Tim.
I'm sorry, I don't have more details, but I believe that there is a small issue in the shock mounts. I think the blazers are different from the trucks in some years because the truck shocks go one forward, one back; while the blazer axles have both shocks to the front. Heads up!
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements. |
So that would just mean relocating the perches, right? Other than that, I could put Blazer axels under a 71-72 Chevy truck, and they would be "as original"?
Chevys Kick A$$
I think they should work but I also think there is something different about the shock mountings but I am not sure what?
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
urban fourwheelin
aren't blazer rear axles narrower than the front?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
The Blazer King
As long as you stick with the same year range it will definatly work. All the front ends definatly swap. 3/4 and 1 ton rears require the above mentioned mods though. Not sure on late model 1/2 ton rears.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
![]() Join Date: Feb 2000
as long as you use '67-'72 vintage axles they will bolt in, the shock mounts are the same, everything. The front axles are actually wider on a 4x4 because of an issue with tracking and the handling characteristics of a 4x4. If you're going to run '73 and up axles, the front is the same, but the rear has different shock mounts, one front and one back, and I've heard the spring perches are wider than a '67-'72. Hope this helps some, btw, how's the Blazer from Ashland coming along?
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
