Old 05-28-2002, 12:54 AM   #1
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Two questions about automatic column shifter..
1) When trying to put it into park, the shifter just won't go. It goes into every other gear easily, but park is a no-go unless you really put some force into it. If I push on the left side of the part of the column that turns with the shifter, it goes into park just fine. I oiled it up, made no difference. There's no problem at the tranny, all gears are fine down there - so I assume it is a column problem. Is there some kind of adjustment I can make?
2) Does anyone make replacement knobs for these things? Mine broke off, and I miss it..
Thanks..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 05-28-2002, 08:34 AM   #2
JimKshortstep4x4
Smile
The shifter tube needs to slide up and down inside the column so that the detent at the lower end will clear. It is real common for the shifter tubes to get sticky and not pull back so as to get it into park. I would try spraying the lower mechanism with a light oil or penetrant and then lubing with a light grease. At the shift lever spray a penentrant into the hole where the shifter lever goes into the bezel and work the lever as you spray. Usually you can hit the slide area that needs lubing.
If the shift tube is not sticking and you still have a problem, you may have some serious wear issues.
Lever knobs are available for you lever, try some of the vendors that are into these trucks, (GMC Pauls, Chevy Duty, LMC, ...)
Good luck!
Jim
Old 05-28-2002, 04:22 PM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Instead of a knob, just find a lever you like and swap it out.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 05-28-2002, 04:34 PM   #4
WB72
Before and After
WB72's Avatar
Whoa! I thought I was the only one. My shifter sticks only when it is coldout. And I mean Canadian Cold. This problem I believe can de cured by Continuous driving, Never park your pride and joy! Seriously, will the column have to be removed for the repair?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 05-28-2002, 05:06 PM   #5
thood
thood's Avatar
son of a gun!! and I thought that I put somthing together wrong! I have the same problem. You guys just ruined my exuse(sp?) to buy a tilt!!LOL
sure wish I could spell (sorry guys)
70 swb restored by myself and some help from this board!!
I hope to drive it some day!! portland OR
thood is offline   Reply With Quote
