Old 05-28-2002, 08:13 PM   #1
JHickson6
I Love This Stuff!
JHickson6's Avatar
454 and 502
What is the difference between a 502 and a 454(besides displacement)?
What parts?
Thanks Guys
JHickson6
JHickson6 is offline   Reply With Quote
Old 05-28-2002, 09:11 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
I don't think there's much, if any differences between the two. I could be wrong, of course. But I think as far as intakes / accessories / heads / exhausts / etc, all big-blocks from 396 to 502 (excluding the tall deck ones, I think) are treated the same way...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-28-2002, 09:13 PM   #3
Cheyenne Super
difference between 454 and 502
If I am not mistaken the main difference is stroke, but the 502 may have a little overbore. The 502 was introduced as a gen iv big block about 14 year ago. The gen iv through vi blocks share just about every feature other than increased strength. Some parts wont interhcange, but most will.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 05-28-2002, 09:17 PM   #4
SCOTI
SCOTI's Avatar
They require slightly different head gaskets & I think 502's valvetrane is not adjustable unless using aftermarket parts, of course the obvious is the bore, hydraulic roller cam vs. flat tappet, aluminum heads, revised timing gear cover & a couple of other things I can't think of.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-28-2002, 10:38 PM   #5
JHickson6
I Love This Stuff!
JHickson6's Avatar
Cool Thank You
Thank Guys for your replies!!!
JHickson6
Old 05-28-2002, 11:23 PM   #6
gearhead dave
Talking
the stroke on the 454 is 4.25 inches and the 502 is 4.5 inches with the bore size the same on both........i think
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
gearhead dave is offline   Reply With Quote
Old 05-28-2002, 11:53 PM   #7
SCOTI
SCOTI's Avatar
Gearhead Dave...not exactly, I think you mixed 'em up. The bore on a 454 is 4.25" stock & the bore on a 502" is 4.47 & both have a 4.00" stroke crank. The other things I couldn't think of earlier were the 502's do not have a provision for a mechanical fuel pump & don't have the threads for a clutch linkage pivot ball for the clutch z-bar linkage(but someone does now make an adapter).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
