02-07-2005, 07:25 PM | #1 |
74 3/4 ton parts.
does anyone need any parts off of a 74 3/4ton no engine tranny may sell the rear. i am located in Nortonville K.y zip code 42442...........all pruces nogaitable.
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops Last edited by TRUCKGUY; 02-11-2005 at 05:57 PM. |
02-07-2005, 07:44 PM | #2 |
It followed me home?
I need a wiper switch
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
02-07-2005, 09:25 PM | #3 |
i will see if i have one and get some pic's tomorow...
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops |
02-07-2005, 09:33 PM | #4 |
ok i have one. is there anyway i can check and see if it is still good? if i get back in time tomorow i will pull it out and get some pic's.
02-08-2005, 02:56 AM | #5 |
ureckmefixit2@cox.net
What color is it inside I need some interior parts in Lt Brown. Matt
02-08-2005, 04:05 AM | #6 |
i need doors and a hood.
02-08-2005, 09:06 AM | #7 |
What shape are the headlight doors and grille opening trim in?
02-08-2005, 10:29 AM | #8 |
Keepin an eye out
I want the front sway bar.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
02-08-2005, 08:27 PM | #9 | |
ok here is the head light switch. the doors have been shot. the hood was broke. the intieior isnt any good all is there is the dash pad and its got crack's. What shape are the headlight doors and grille opening trim in? you mean the grille and the head light rings? i'll have to check on the sway bar. heres some pics of the switch.
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops Last edited by TRUCKGUY; 02-08-2005 at 08:54 PM. |
02-08-2005, 08:36 PM | #10 |
how much??
02-08-2005, 08:38 PM | #11 |
i don't know never bouht one or sold one before.....what will you give?
02-09-2005, 02:13 AM | #12 |
You know i really dont need this peice and if i do there are more i can get cheap around here from my uncles junkyards.........and i am sure you need it and can get some use out of it so i will let you have it does that sound good?? ............need a address....................
you can email me here at danschevyinky@yahoo.com let me know thank's
02-10-2005, 01:52 PM | #13 |
Keepin an eye out
Still interested in that sway bar.
02-10-2005, 05:23 PM | #14 |
i am bout to go take it off just got on to check and see what all i need to take off be back with pic's in a while.
02-10-2005, 06:47 PM | #15 |
pic's
the sway bar is good bushing arent or brackets. i have two grills 1 for a 454 and 1 350 both have some cracks in them. i think i have a good set of head light rings to.
02-10-2005, 06:50 PM | #16 | |
huh? nver heard it called that before? explain and i can get some pics.
02-10-2005, 08:40 PM | #17 |
Keepin an eye out
On the sway bar, are the areas under the bushings still round(not rusted) as the rest of the bar? The last one I bought had contours under the bushing areas from rust.
Also its off 2wd 3/4 ton for sure? How much $?
02-10-2005, 09:07 PM | #18 |
yeah its got some rust not as much but it is still round??
02-10-2005, 09:17 PM | #19 |
here ar esome pics of where the bushings were.is this what you want? i dont know how much i will have to find out the shipping.
02-10-2005, 09:18 PM | #20 |
some sanding would probly take the rust off and then it would work good i guess.???
02-11-2005, 09:51 AM | #21 |
Keepin an eye out
Looks ok...last one I bought shipping from Pa. to Ca.(91355) was $20....So what kind of delivered price are we looking at?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 02-11-2005 at 04:46 PM. |
02-11-2005, 05:58 PM | #22 |
i will have to look and see what shiping is make a ofer.
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops Last edited by TRUCKGUY; 02-11-2005 at 08:14 PM. |
02-11-2005, 06:29 PM | #23 |
Keepin an eye out
Sent a PM.
02-13-2005, 01:41 AM | #24 |
Keepin an eye out
Hey TRUCKGUY bought a different sway bar, thanks anyways and a TTT for ya!
02-13-2005, 07:52 PM | #25 |
i'm interested in the sway bar. what diameter is it? how much $$ for the bar and to ship to 58102?
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
