Old 02-10-2005, 04:57 PM   #1
Goffer
Goffer's Avatar
Autometer Fuel Level
Having trouble getting an auto meter fuel gauge to work. I used what I thought was the sending wire from the original cluster harnes. How would you all hook it up and how can I be sure I have the correct wire (other than color, my truck has had an interesting electrical history).
P.S. the whole dash in now Autometer's Cobalt gauges, very happy with them.
'71 C10 swb 350sb/700r4
Goffer is offline   Reply With Quote
Old 02-10-2005, 05:59 PM   #2
GreyHoundSteve
Hey goffer, run a search because i know a couple of guys have posted solutions to your problem with the autometer gauge. I cant remember exactly what was said but i remember that your are NOT suposed to use the factory harness the way it was originally hooked up.
GreyHoundSteve is offline   Reply With Quote
Old 02-10-2005, 07:06 PM   #3
Goffer
Goffer's Avatar
will do, thanx
Old 02-10-2005, 08:21 PM   #4
greasemonkey
greasemonkey's Avatar
I used one of the two fuel wires from the stock connector but cannot for the life of me remember which one it is, I think it was tan.
You can always just run a wire from the sending unit in the tank directly to the guage itself, might be easier and faster for you than hunting down the correct wire in the connector.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-11-2005, 04:11 AM   #5
Mudder
Mudder's Avatar
I think there are about 3 tan wires in that harness, so I found the tan wire coming from the tank under the fuse box and spliced in there.
Mudder is offline   Reply With Quote
Old 02-11-2005, 04:49 AM   #6
Goffer
Goffer's Avatar
I found the correct wire from the harness. There are several brown and tan wires in the harness. I knew I had about 3/4 tank, one of the tan wires read 68 ohms, so I knew where to go from there.
