Old 02-10-2005, 06:38 PM   #1
'70_402
'70_402's Avatar
Tach on new distributorless ignitions??
How do you hook up a tach on a distributorless ingnition motor.....got a sand rail with a 98 ford 4 cylinder in it and was wondering how i hook up a tach...no distributor??? anyone done this??
Rick
'70_402 is offline   Reply With Quote
Old 02-10-2005, 07:09 PM   #2
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
You can use a magnetic pickup. Not sure of the implications, but I know this pickup can be used for the tach signal. Think it measures crank rotation by the harmonic balancer somewhere.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 02-10-2005, 09:42 PM   #3
Eddie H.
Eddie H.'s Avatar
The Ford 2.3 in the Ranger gets it's rpm signal from the crankshaft position sensor to the computer ( PCM)
Ford calls this signal the PIP ( profile ignition pickup) The factory tachs in these pickups use a tach signal sent from the pcm to the gauge cluster. I'm not sure if an aftermarket tach would be able to operate properly using this same signal or not?
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-10-2005, 09:49 PM   #4
Eddie H.
Eddie H.'s Avatar
oops. I guess I didn't read your post very well. I thought you said you had a 4 cyl from a 98 Ford Pickup. Anyway, if it's from a car, the DIS ign systems all operate basically the same way.
Old 02-11-2005, 11:11 AM   #5
'70_402
'70_402's Avatar
it is from a pickup...where would the signal come out at?? would there be markings on the pcm??? does anyone have a diagram for this??
Old 02-11-2005, 09:38 PM   #6
Eddie H.
Eddie H.'s Avatar
If you're using the original Ford wiring harness, The 104 pin connector that
goes into the PCM should have very small numbers on the back side that correspond to each pin. The tach signal wire out of the pcm is a tan wire with a violet stripe. It comes out of pin 48.
Old 02-11-2005, 10:08 PM   #7
gmc67swb
gmc67swb's Avatar
WOW, how long have you been sitting on that information? Do you work on these things daily or what? Very impressive.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-11-2005, 11:36 PM   #8
Eddie H.
Eddie H.'s Avatar
Yea, I work on Fords for a living. I figure that a good doctor needs to be where the sickest patients are
Old 02-12-2005, 11:06 AM   #9
gmc67swb
gmc67swb's Avatar
I like that. You're pretty close to the airport right? I work at 360 and Trinity,"Ft Worth"
Old 02-12-2005, 12:02 PM   #10
Eddie H.
Eddie H.'s Avatar
I guess we're practicaly neighbors then, I just live a few miles west of there.
