Old 02-11-2005, 10:58 AM   #1
T_Raven
T_Raven's Avatar
front suspension question
i have a 72 gmc 2wd 3/4 ton. does anyone know if there is a five lug rotor that will fit in place of my 8 lug ones. or even a rotor and spindle combo that will bolt to my A arms? I have a nice set of five lug wheels, (5x5 and 5x5.5 bolt patterns) a new rear axle is easy, but i'm curious what parts i can put on the front without having a wider track width like the 73-87 trucks, thanks.
T_Raven is offline   Reply With Quote
Old 02-11-2005, 02:48 PM   #2
68jimmy
68jimmy's Avatar
Without changing the a-arms and spindles you will not be able to get a 5-lug rotor to work. ECE does sell a spindle conversion kit that utilizes your existing 3/4 ton a-arms/ball joints and allows you to either install a 5 or 6 lug rotor. Your'e probably better off finding a 71 to 87 1/2 ton and grab the front suspension setup, brakes and all. In the long run replacement parts will be easier and cheaper to find....
good luck!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-11-2005, 06:29 PM   #3
T_Raven
T_Raven's Avatar
thanks 68jimmy, i read on another thread that the 73-87 have a different track width, and that i would have to use the a arms from those years too if i went that route. anyone know few parts i can use from the newer trucks?
Old 02-11-2005, 07:50 PM   #4
Zeke
Active Member
I remember seeing conversion vans in the 80's which had the 20 badge for 3/4 ton but with 5 lug rims. Don't know if those would work? Anyone know? Never into vans, just thought it odd.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
