Old 02-15-2005, 03:43 PM   #1
1Ton
1Ton's Avatar
Dana 60 Help needed
I got a Dana 60 out of a 79 K30 that is full time 4wd. I want to put a set of locking hubs in it. What do I need to do to convert it? Besides get the locking hubs.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 02-15-2005, 05:01 PM   #2
1969 GMC
1969 GMC's Avatar
thats it!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-15-2005, 05:09 PM   #3
1FaastC10
1FaastC10's Avatar
providing your hubs have the snap ring groove...
1FaastC10 is offline   Reply With Quote
Old 02-15-2005, 05:42 PM   #4
1Ton
1Ton's Avatar
Thats what I thought too. Didn't want to get started and need more parts. Thanks guys.
if some is good
more is better
Old 02-16-2005, 01:02 PM   #5
1Ton
1Ton's Avatar
Called 4 wheel parts they said there is a convertion kit that is needed besides the hubs.It is $50 so I will be getting that too.
if some is good
more is better
Old 02-16-2005, 01:06 PM   #6
muddobber40
No theres not. I have had 3 ful time 60's. . Pull the drive flanges out, should be a spring sometimes not, install your new manual hubs and go..
muddobber40 is offline   Reply With Quote
Old 02-16-2005, 08:24 PM   #7
LONGHAIR
The conversion kit is for the transfer case. (assuming that you have a NP203. which is a full time 4 wheel drive unit)
Yes you do need it if that is in fact the case you have.
It is a gear that replaces some spider gears inside the rear housing of the transfer case. It is fairly simple, most of the kits that I have seen have good pictures/directions.
LONGHAIR is offline   Reply With Quote
Old 02-16-2005, 11:46 PM   #8
1Ton
1Ton's Avatar
Interesting no I do not have that case mines a NP205. They said it is for the axle to accept the hubs. Puting the axle in to a half ton.
if some is good
more is better
Old 02-17-2005, 12:15 AM   #9
1FaastC10
1FaastC10's Avatar
what happened to all of the a's in this thread?
Old 02-17-2005, 12:17 AM   #10
muddobber40
Never seen a 1 ton with a 203. Mine all had the 4sod/205 combos that had the full time hubs
You don't need the kit. all chevy 60 srw hubs are the same be it manual hubs, full time hubs or automatic hubs.
Old 02-17-2005, 06:41 AM   #11
LONGHAIR
If it doesn't have the NP203 transfer case it it not "full time 4 wheel drive" as stated in the original post.
Old 02-17-2005, 09:58 PM   #12
1Ton
1Ton's Avatar
I have no idea what the donor truck had for a Transfer case. Just wanted the 60 out of it.
if some is good
more is better
