Old 05-30-2002, 08:28 AM   #1
8mag
4x4 lift kit,which is best
have a tuff country 4 spring lift know and it rides harsh,are there any soft ride kits that are soft". looking to buy 4 new springs.
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers
daily driver
other trucks
1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel
8mag is offline   Reply With Quote
Old 05-30-2002, 09:05 AM   #2
Bram
Broke
Bram's Avatar
Cool
Hey 8mag, I'm using Skyjacker Softrides right now, and the ride is actually very good. I live down 3 1/2 miles of very rough gravel road, so it gets tested very well! One thing I did give up is load support in the bed? But I do plan on installing air bags in the rear, that way I have the best of both worlds!?!?
I noticed the spec's on your 1972, 3/4 4x4, 14bolt locker rear, dana60 and locker front, nv4500, 383, blazer tank, dual batterys, 4" lift, 285-75-16's. That’s pretty much exactly what I would like to do to mine! You don't by chance have any pics?
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 05-30-2002, 09:09 AM   #3
Mike C
Mike C's Avatar
To some degree, a 3/4 ton is just going to be rough. I would start by getting some adjustable shocks and playing with those as well as dropping your tire pressure. I'm sure max load is at least 50 psi if not 65 on your tires. Try running them around 35 when you aren't carrying a load, maybe less. The bigger the tire, the less psi it needs. Another option for the rear would be a Velvet Ride Shackle combined with your existing springs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-30-2002, 11:36 AM   #4
Bram
Broke
Bram's Avatar
Question
8mag, what type of lockers are you using in the front and rear?
Old 05-30-2002, 11:59 AM   #5
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
I'd definately suggest greasable shackles all the way around, they not only can provide some lift and great suspension flex but helped rides in my 4x4ing vehicles a ton.
just my .02
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-30-2002, 12:07 PM   #6
Mudder
Mudder's Avatar
what shocks u running?
I am running rancho 9000's and they ride great. 20-25 lbs of air in 35/1550 super swampers. i also have heavy duty tuff country springs.
Mudder is offline   Reply With Quote
Old 05-31-2002, 08:25 AM   #7
8mag
i have detroits in the front and rear lots of noise when i tow. just got then truck painted and took some pics will see if i am smart enough to post them.
daily driver
other trucks
Old 05-31-2002, 10:34 AM   #8
Bram
Broke
Bram's Avatar
Hey 8mag, did your truck have an automatic trans originally? If so how hard was the conversion to the NV4500?
Old 06-03-2002, 04:32 PM   #9
Bram
Broke
Bram's Avatar
ttt
Old 06-03-2002, 10:15 PM   #10
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
how do the dual detriots handle on the street?
68SWB4x4 is offline   Reply With Quote
Old 06-04-2002, 01:24 AM   #11
Scrub
Collector of rusty Items
Scrub's Avatar
Look into that new Eaton Electric locker. Detriots suck on the pavment.
http://www.traction.eaton.com/prod1.htm
http://www.rockcrawler.com/techreports/eaton_elocker_preview/index.asp
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-04-2002, 04:51 PM   #12
8mag
thandles fair on the street but icy roads cause white knuckles over 40mph and i commute 50 miles a day.
daily driver
other trucks
Old 06-04-2002, 04:53 PM   #13
8mag
truck was a 4spd originally used a dodge 4500 and had a shop do the work, not really worth the cash outlay, only gained 2 mpg from 12 to 14, when towing am in 4th gear anyways.
daily driver
other trucks
