02-23-2005, 12:12 AM | #1 |
Motor mount torque
How much do you torque motor mounts to on a 350?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-23-2005, 12:20 AM | #2 |
Tight. no TQ figures.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-23-2005, 12:26 AM | #3 |
Every bolt, nut and screw on a vehicle has an installation torque value. If I can find my assambly/service manual I will post the value.
02-23-2005, 12:58 AM | #4 |
place socket on impact fun place socket over bolt and pull the trigger till it stops turning then they are tight enough
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-23-2005, 06:32 AM | #5 |
its all about the +6 inches
While aesj2 is technicly right, there is a torque reading for every bolt...you'd be wasting your time.
Drive it on with an impact. If you have no air tools, then tighten it down with your 1/2 inch drive ratchet. Put some ass on it, but no need to pull hard enough to get a hernia or break anything. |
02-24-2005, 02:32 AM | #6 |
Just to think of all the time and money G.M. has wasted on engineering and equipment to install bolts. All they had to do was buy a big impact wrench.
02-24-2005, 02:42 AM | #7 |
68cst_ss490
Not sure what the torque is but you could go with GErman torgue which is Goodentight Just make sure you dont use russian torque which is Brokenoff
lol hope I ooffended no one with this
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
02-24-2005, 02:57 AM | #8 |
I always got a kick out of "quarter of a turn before it breaks off." Actually if you get in the habit of torquing everything 2 things will happen.
1: You will not break a bolt off. 2: Stuff will not fall apart. Here is a link to a torque table that you can use. Torque table
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
02-24-2005, 02:59 AM | #9 |
, good one Dean.
02-24-2005, 03:17 AM | #10 |
So whats the tourque value for my muffler bearing output shaft.........if I use 90wt. on the first half of the threads, and DextronIII on the second half, and fully synthetic on the third half?
02-24-2005, 03:34 AM | #11 |
Professional Grade
50 - 65 ft lbs is what my book says for my 80's engine mounts. I put them at 60 ft lbs
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-24-2005, 04:31 AM | #12 |
If we want to get completely technical, we'll need to look at the bolts and determine if they are stretched and or fatigued. Then, you can clean the threads and chase them with the proper tools, and only then can we install the bolt. This of course after inspecting the washers and replacing any lock washer that may have been installed 35 years ago and left out at some point by some shade tree mechanic with an impact.
Lets look at the torque reading given for the later style motor mount. When you installed the old used bolt, in the dirty hole with no light weight oil...there is no telling if the bolt is actually torqued down properly. Regardless what the torque wrench says, it is not giving an acurate reading of the bolt's clamping ability at that given reading. The dirt will cause resistance....higher reading The lack of a light weight oil...will cause a higher reading The rust on the bolt....higher reading The fatigued bolt will give an inacurate reading (not sure which way) So if we are going to be technical...let's get it right. Grab an impact or a 1/2 inch ratchet, and tighten it up. If it makes you feel better, put some lock tight on the threads. I always say, torque it down untill it spins freely, then back off 1/4 turn. |
02-24-2005, 04:42 AM | #13 |
Who needs bolt, WELD IT ON.
02-24-2005, 04:45 AM | #14 |
nahh welding wouldnt work so good being that the block is cast iron and the mounts are steel. impact gun would still work much better
02-24-2005, 05:53 AM | #15 |
JB Weld? Glue? Bubble gum........
02-24-2005, 10:00 AM | #16 |
Professional Grade
I like the bubble gum idea
I do believe that your torque would be stronger with fatigue, as the bolt will be stretched out past the threshold, causing it to coagulate and not go back to it's original shape... This means that the bolt wouldn't stretch out anymore any time soon, making the torque you put on be more than it would have been before
02-24-2005, 09:24 PM | #17 |
68cst_ss490
Ahhh nothing tighter than a good crossthread anyways
02-24-2005, 11:15 PM | #18 |
Lofl!!!!
02-24-2005, 11:21 PM | #19 |
If you're talking about the bolts going into the block, standard torque for a 3/8, grade five bolt is 30-35 lbs, grade 8 is 45-50.
02-25-2005, 01:00 AM | #20 |
Got Light Emitting Diode?
you guys forgot the obvious, duct tape and bailing wire. those two things used seperatly or together will solve any problem
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
02-25-2005, 01:22 AM | #21 | |
You forgot pliers HAHAHHA
02-25-2005, 01:29 AM | #22 |
Msgt USAF Ret
Is that like a lot of these threads being cross posted or Versa -Vicesa?
I couldn't get a torque wrench into my 67 mount bolts anyway Vettevet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-25-2005, 08:54 AM | #23 | |
Watch out for your cornhole !
I get a laugh every time I see his name in a post.
02-25-2005, 10:13 AM | #24 | |
02-25-2005, 10:46 AM | #25 |
Run a logging chain across the motor left to right drill holes in the crossmember and bolt it down. But then again what would be the torque specs on those bolts ??????
Certifiably crazy person |
