Old 02-24-2005, 12:14 PM   #1
wolfthing2000
Formulas for a 400 SB
Any simple economy builds for the 400 SB to gain power at a ground level budget???
Dave
wolfthing2000 is offline   Reply With Quote
Old 02-24-2005, 12:34 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
instead go with a 383. same torque but without the common overheating issues.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-24-2005, 12:58 PM   #3
breeh
Recovering 67-72 Addict
breeh's Avatar
It is my understanding that the overheating issues with the 400 are a myth. Usually when a 400 overheats it is because heads have been put on without the steam holes.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-24-2005, 01:29 PM   #4
browndawg71
400 sb . vortec heads , performer rpm airgap intake, headers . cam with around 230 degrees duration @ 050. you really need to give up more details about what you are going to do w/ this motor( . race , street , 4x4)
every man must believe in something, i believe ill have another beer!
browndawg71 is offline   Reply With Quote
Old 02-24-2005, 02:29 PM   #5
c10-377
c10-377's Avatar
I beleive that the overheating problem is a myth also. I have had a couple of 400 sb and never had any problems. Just make sure you have the right head gaskets and the right heads with the steam holes for them. Well, I take that most any head will work you have to take the head to a machine shop to have steam holes drilled. The motor I have now is a 400 bored .040 over and I have no problems with overheating.
1969 c10 2wd 377 destroked 500hp
- In Planning stages of a 700hp 8-71 blown 406 sb
1990 ranger 2.3L 250k and counting
I want my truck to have enough power that im afraid to put it to the floor
c10-377 is offline   Reply With Quote
Old 02-24-2005, 02:31 PM   #6
Bowtiefreak
Bowtiefreak's Avatar
First I mean no disrespect but the statement on overheating is very in-correct. 400's will stay cool with no problem provided the steam holes are drilled in the heads as mentioned earlier.
wolfthing2000-
What do you want to do with the motor as mentioned by browndawg71?
400's are great little motors. See my sig.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 02-24-2005, 07:33 PM   #7
wolfthing2000
I am planning the engine for a 3/4 ton 4x4. for casual driving and some towing / camper hauling. Hopefuly put together with some late 60s 327 heads that I have.
Dave
Old 02-24-2005, 08:53 PM   #8
racer face
4 bolt main blocks have weak webbing. If you need torque motor use a two bolt block
with four bolt main caps and have a machine shop drill the extra holes.
Make sure head gaskets have all the passage holes open.
Pat
______________________
1968 1 Ton Dually Flatbed 327/th400
1968 C30 Open Road 327/th400
1997 F350 CREWCAB 4X4 460 BIGBLOCK
racer face is offline   Reply With Quote
Old 02-25-2005, 01:10 PM   #9
wolfthing2000
Am I on the right track with the heads?? I have an Edelbrock manifold with a Quadrajet to use for now and I will use Headman or such long tube headers and Dyna- Flow or similar mufflers RV cam.
Old 02-25-2005, 03:50 PM   #10
BigDave
I poop on Ford!
BigDave's Avatar
I have a slightly built 400 SBC in my Blazer.
It has a rebuilt 850 cfm Quadrajet sitting on an Edelbrock Performer intake. I slapped a nasty old set of headers on it. It has a Lunati 292 cam and timing set. I installed 9.5:1 pistons and some decent heads. It also has the much recommended HEI electronic ignition and a serpentine belt system. One thing I would definatley redo is install an electric fan(s) and get rid of fan/clutch/shroud stuff.
I like it. If I drove it more often I would probably prefer a stroker or a big block. It gets down the road, sounds great, and eats up pavement when I want it to. I have no complaints.
1972 Chevy Cheyenne - LWB, factory 402BB
2005 Chevy Suburban LT
2006 Chrysler 300C - SRT8
BigDave is offline   Reply With Quote
