Old 02-24-2005, 08:54 PM   #1
davidh
davidh's Avatar
Putting in a 89 seat in a 67??
Okay. I've seen this swap many a time before but when I casually dropped in the seat I noticed it aligns at the front but it sits way too low. How do I bring it up? As it sits I feel like my truck seat positon makes me feel as if I"m in a 79 camaro.
davidh is offline   Reply With Quote
Old 02-24-2005, 08:54 PM   #2
davidh
davidh's Avatar
seat
the seat is out of a 89chevy.
Old 02-24-2005, 09:12 PM   #3
john_doe
My bench was junk so I tryed a differant bench seat (not sure what it was from) and it made me sit to far forward. I'm 6' and have a standard so having leg room is a must. If you find a bench that works can you post it here? Thanks
john_doe is offline   Reply With Quote
Old 02-24-2005, 09:29 PM   #4
gr8scott51
gr8scott51's Avatar
Adjust the seat so that the mounts sit behind the raised lip in the seat area. I didn't try using the original holes, I just drilled 4 new ones. I'm 5'10" and the mid 90's silverado bench I used fits great, even with the tank in the cab. Classic Truck or Custom Classic Truck did an article on different seats a couple months ago.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 02-24-2005, 09:41 PM   #5
neonlarry
neonlarry's Avatar
I just used a couple of nylon furniture shims to raise the front slightly.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-24-2005, 09:51 PM   #6
72 Cheyenne402
72 Cheyenne402's Avatar
Where could I find this artical? "Classic Truck or Custom Classic Truck did an article on different seats a couple months ago."
72 Cheyenne402 is offline   Reply With Quote
Old 02-24-2005, 11:23 PM   #7
James67
New Member
August 2004 Classic Truck Magazine
James67 is offline   Reply With Quote
Old 02-25-2005, 12:37 AM   #8
Blue_71
Bloo
Blue_71's Avatar
i put an 89 bench in my k20.. i have a 4 speed in it, with the original 18" steering wheel. it has plenty of room. it did sit to low but i took some 1" square stock and made 4 small peices and drilled 4 new holes
Blue_71 is offline   Reply With Quote
Old 02-25-2005, 01:17 AM   #9
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i done this on the 69 and 72 used the front holes and drilled new rear holes and made a spacer for the rea to hold it up level.i didnt like how high the seat set so the metal frame that runs around the bottom we cut it in half and removed 2 inches and weldedit back.
IF YOU MAKE NEW HOLES USE SOME BIG WASHERS SO IN A CRASH THE BOLTS WONT RIP THRU FLOOR BOARD
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
