03-07-2005, 08:11 PM | #1 |
What Year 16" Wheels Will Fit?
Hey, anyone know what year wheels will fit our trucks? Thinking about buying some 16" ralley wheels for my K5. I have located a set off a 88 or 89 but was wondering if the offset is correct.
Thanks. ...Dan |
03-07-2005, 09:05 PM | #2 |
DAN"L I have a set of American Racing wheels that were on my blazer when I got it. They are 16 x 8 inches. I'll take 100.00 for them and they have 265 75 16 on them now may pass inspection. I also have the center caps too. moodyholler
1998 WRANGLER I-6 auto 1972 LWB FLEETSIDE 1968 GMC SWB STEPSIDE 1994 C-1500 SWB 4.3 5 SPD |
03-07-2005, 09:51 PM | #3 |
Moody, thanks for the response. I will keep your wheels in mind but really was wanting a set of 16" stock wheels or GM ralley wheels.
...Dan |
03-08-2005, 08:01 AM | #4 |
The only stock 16 inch wheels that will fit these trucks properly are the ones that were optional during these years, and they are very rare. The '88 and up wheels have the wrong offset (way too much backspacing), and the center holes are too small.
Tim |
03-08-2005, 09:40 AM | #5 |
Thanks Tim
Thanks for the info Tim. I will narrow my search.
...Dan |
03-08-2005, 12:19 PM | #6 |
SKINNY TIRES RULE!
I don't think any of the ralley wheels were 16 inch. I have heard of people getting newer alluminum wheels machined so the center hole fits over the hub. I don't know if you could do the same with steel wheels.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-08-2005, 06:22 PM | #7 | |
Tim |
03-09-2005, 10:10 AM | #8 |
Thanks Again
Thanks again guys. I have found, thanks to Bouncy, some custom ralley wheels that may work.
...Dan |
03-22-2005, 02:21 PM | #9 |
I would like to know what and where you
found your 16" Ralley Wheels. Also what size tire will fit with out a lift? Thanks,
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
03-22-2005, 03:38 PM | #10 |
SKINNY TIRES RULE!
I don't think he found 16" ralleys, just steel 16" wheels. Stocktonwheel.com
03-23-2005, 12:41 AM | #11 |
I found a site that can make 16" or 17" 59 Series - GM K-10 Ralley Wheels.
http://www.stocktonwheel.com/light_truck_wheels.htm
03-23-2005, 09:55 AM | #12 |
'71 Chevy Blazer
what were those wheels that were on the add that somebody posted a while back? remember that post where everybod was trying to see what was wrong in the picture? it was a K5 with a bench seat in the front? somebody was talking about those wheels being odd too
'71 K5 Blazer (new project / daily driver) "If you are not working to improve the situation, you have no business complaining" |
03-23-2005, 12:58 PM | #13 |
SKINNY TIRES RULE!
I think GEE EMM Posted that picture. It was from an ad in '69. Who knows what wheels those were because I pretty sure that was a pre-production model.
03-24-2005, 12:47 AM | #14 |
Wheel Vintiques
Hey Hatguy, Stockton Wheels for the steelies and Wheel Vintiques for the ralley wheels.
http://www.wheelvintiques.com/ Not sure what size tires will fit without mods but I think the stock look of Bouncy's K5 is awsome. http://67-72chevytrucks.com/vboard/s....php3?t=107177 ...Dan |
03-24-2005, 07:27 AM | #15 |
Stockton Wheel can make this wheel 16" or 17"with
the right off set in chrome. painted or podwer coated. 59 Series - GM K-10 15x10 4x4 Rally with Factory Cap & Trim Ring If you're like a lot of other Chevy/GM 4x4 enthusiasts who like the looks of their 15" OEM wheels but want to use a wider or larger tire, Stockton Wheel has the cure. Stockton Wheel can turn your 15" wheel into a 16" or 17" wheel OR widen your 15x8 wheel to a 15x14! You can even choose your own backside setting.
03-24-2005, 12:29 PM | #16 | |
SKINNY TIRES RULE!
03-25-2005, 12:10 AM | #17 |
Funny you should ask Bouncy. I had planned to bid near item end time but went to the salvage yard and did not return in time. Salvage dude said disc brake wheels are different from drum brake wheels. I actually bought four wheels but only two are road worthy. The other two have elongated lug holes. Think I can use one of those as a spare though. I did not see the set yesterday.
Regardless who gets the credit they look great. ...Dan |
03-25-2005, 02:23 AM | #18 |
SKINNY TIRES RULE!
Never heard of disc wheels being different. Wouldn't that mean that I couldn't rotate my tires because the front is disc and the rear is drum? I'll have to check that out.
03-25-2005, 09:30 AM | #19 |
Good Qusetion
Salvage dude had both type wheels. The difference is the bevel on the backside of the drum brake wheel will not clear the disc rotor. I assume only the disc brake wheels were produced after that option became available. If that is true it really should not matter to anyone with wheels that originally came with their trucks. However it could matter, assuming it is true, to someone purchasing a set of wheels to place on a truck. Urban legend or not?
...Dan |
