Old 03-21-2002, 04:18 PM   #1
VNMOUS
Step Side's Rule
Question amp gauge
Where does the hot wire from the amp gauge hook up?
DANO
67shortstep:350/350,flows,headers,3:08posi,edel intake & carb
76 stingray
95 cobra
IBEW 558
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 03-21-2002, 07:19 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
fuse panel ign source
Fast68Chevy is offline   Reply With Quote
Old 03-21-2002, 07:38 PM   #3
StingRay
StingRay's Avatar
Post
There are two hot wires. Both terminate under the hood, one on either side. You'll find one hooked up to the junction block next to the battery and the other on the drivers side at the junction in the main power feed from the fuse block where it tees off between the alternator and the battery. Both have little rubber fuse holders on them on the under hood ends. It is called a shunted ammeter and this is how it works. The amp gauge actually measures the voltage drop between the T junction and the terminal block by the battery. It uses Ohms law E=IR or I=E/R where I=amperage, E=voltage and R=resistance.The resistance of the wire is known, the voltage difference is measured by the gauge and via the formula I or amperage is what is displayed. Probably more than you wanted to know.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
