03-22-2005, 08:36 PM | #1 |
Just like to part out trucks!!
pics for C-1072!!
This is the same place on frame just 2 different pics. I don't see any other rust on it. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
03-23-2005, 06:57 PM | #2 |
frame
This is what i have to work with do you think you can cut it lower than this for me .
03-23-2005, 08:56 PM | #3 |
JB-80 "Twice as Good"
Randy & c-1072-
Don't know how involved you want to get in cutting this apart......but the one I did last summer I cut with a sawzall along the red line (exact same measurements on both donor and reciepient) Used a 10" saw blade and cut was lots straighter than I can draw . Then took the dash out-that plate sticking up with the red arrow pointing to it is held in by the bolts that go thru the sides of the dash.....with those bolts out a guy can simply slide the old out and new in. Then put the bolts back in,(and I had the top on)-the bolts will hold it together while you weld it back together. Can't tell where the splice was on mine-and worked really good. Only wish I had taken pics of this.....but was too excited to get her back together! Let me know if I can help! -Galen.
HEY NOW! |
03-23-2005, 09:02 PM | #4 |
thanks
I realy appreciate the info I was realy struggling with how it was sandwiched all together . I hope it all works out the the tub i got is rock solid it just looks like sombody rolled it down a hill or two .
03-23-2005, 09:14 PM | #5 |
......forgot to add-when cutting,only cut the outside metal (if that makes sense?) That plate is way over on the other side by the dash-and extends about 8-10" down from the cut line-so you won't get it by accident-but if you keep sawing all that work will be for nothing! Damn-why did'nt I take some pics!?! (and save a thousand words).
HEY NOW! |
03-23-2005, 09:44 PM | #6 |
It will be the weekend before I can try anything, Galen so just cut the outside over to that plate on both sides, then take the bolts out of the dash and it will all slide out? Do I have to take the dash all the way out? Trying to make sure I understand. Thanks Randy
03-24-2005, 12:36 AM | #7 |
frame
That sound about right to me i didnt know if it was spot welded near the dash at all . I could also do a trial run on my old tub the frame is solid at the base if it would help , i could take pics .
03-24-2005, 08:31 AM | #8 |
Yes-I think there are some spot welds involved on the inside.....I'll take some pics before this weekend. Only reason a guy did it this way-I was'nt too sure about my welding skills-and all the splices are covered by the cowl and doors. Plus having that plate to bolt in kind of takes the guesswork out of alignment.....
HEY NOW! |
03-25-2005, 12:45 AM | #9 |
frame
well keep me posted i could sure use it sooner thn later . I am gonna clean the frame and paint it this weekend . I also picked up the body bushing kit . got to getthe bolts still .
03-25-2005, 09:25 AM | #10 |
If you could do a trial run on yours too, that would help. it will be Sun morn before I can get out there. Thanks Randy
03-25-2005, 04:43 PM | #11 |
Randy-If you're not going to save the dash-just go to town with the saw! Stay below the bottom of the dash, below the bolt hole for the front fender,and just slice the dash. C-1072 will be able to "perform surgery" and trim it to fit. I'm no expert,or bodyman......this is just what worked for me. Wish a guy was closer-
HEY NOW! |
03-25-2005, 04:45 PM | #12 |
-the red line is where I cut and spliced.....if you stay below the dash you'll miss that plate inside.
HEY NOW! |
03-26-2005, 06:30 PM | #13 |
I got the windshield out and found this in pass top corner. Its cut off the Jimmy now. Thanks for the help Galen!! I'll pm you C-1072. Thanks Randy
03-26-2005, 06:31 PM | #14 |
forgot pic
