03-30-2005, 10:03 PM | #1 |
....Headliner install in a non headliner cab???????
...anybody done this?...after i get the truck painted i would like to put a headliner in it but its a non headliner cab...i'm guessing the only way to do it is to cut the slots in the roof for the trim?..
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
03-30-2005, 10:18 PM | #2 |
my truck never had a headliner. when i had the upholstery done i had them make a padded headliner and install it with velcro. no screws, no trim. works great
03-30-2005, 11:25 PM | #3 |
In order to get the headliner trim to not sag you need to make the slots for the trim. It's a pain but can be done.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
03-30-2005, 11:50 PM | #4 |
its all about the +6 inches
You don't need the slots, you don't even need the trim. The headliner is supposed to be glued in place.
You can glue it in there, take the trim, break off the tabs that require the slots, and then just drill the holes for the screws. MAKE SURE YOU USE SHORT SCREWS !!!!!!!!!! I don't have the pic here...but the old GMC had screws pokin through the cab roof from the dope smokin old man that had it before me. |
03-31-2005, 07:39 AM | #5 |
I used screws on mine and glue. IMO they look better with the trim around them. Screws need to be very short. Come to think of it I used double sided tape.
03-31-2005, 08:15 AM | #6 |
one set closer
take a look at this it might help it's from brother web site.
http://www.brotherstrucks.com/tech/t...20INSTALLATION |
03-31-2005, 10:12 AM | #7 |
Great stuff from the Bro site THANKS~!!!
03-31-2005, 10:51 AM | #8 |
I just used 3M weatherstrip adhesive/no trim.Had the truck 12 years,stayed there fine.Trim would be nicer.I did it before repro days.
03-31-2005, 06:11 PM | #9 |
thanks guys..i figured i could glue the headliner up but i definatly want the trim but the thought of cutting all those slots sounded like a real PIMA but screws or 2 way tape sound good...scary thing will be buying new trim then cutting off the tabs without breaking the rest.........
03-31-2005, 11:15 PM | #10 |
Questionable
I saw one yesterday in a JC Whiteny catalog for our truck and I'm pretty sure it used adhesive as well.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-31-2005, 11:34 PM | #11 |
my cab is a headliner cab and i freakin hate it....i need to get another cab lol.....i figure if i try to weld them up i'll warp it....and i SERIOUSLY HATE the headliners.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
03-31-2005, 11:37 PM | #12 |
Questionable
You can use fiberglass plugs for small holes like that. That's what we used on my '03 Sierra to plug up the holes in the tailgate (the ones for the protective trim at the top) when I shaved it. Those were square shaped holes. The little fiberglass plugs worked well.
03-31-2005, 11:48 PM | #13 |
what are fiberglass plugs?
04-01-2005, 12:02 AM | #14 |
Questionable
I dunno, the guy that helped on my truck lives across from my parents down in the bar area of florida. He used some kind of fiberglass stuff to fill the holes in my tailgate, wiated for it to harden, then sanded it flat. Thye stuff plugs the hole and makes a small lip inside to catch the lip of the tailgate. He said this was the way he preferred to do things versus welding stuff shut.
Like this: http://www.sporttruck.com/projectbuild/1448/ Look at the fourth and fifth panel down. It's like some kind of fiberglass epoxy that's used to plug up the hole. Fiberglass doesn't rust or warp like a welded body panel will. I don't know why people still weld stuff shut. This is supposed to be a lot easier for plugging holes. But ... I'm no body worker. You tell me - See the four holes in the top of my tailgate? http://www.shifty.org/pics/truck/bod..._tailgate2.jpg Now, look at the four holes after - they were filled with fiberglass just like in that article: http://www.shifty.org/pics/truck/body_work/after2.jpg Man, I really miss my old truck
04-01-2005, 12:16 AM | #15 |
there is also fusor you can do that with...
04-01-2005, 12:25 AM | #16 |
Questionable
fusor?
