04-05-2005, 11:32 AM | #1 |
Still Green but learning
Synthetic Oil
I just changed the oil in my Yukon and have started using a synthetic blend. I really like it, it has cut down on the initall knocking that I was getting when cranking cold. I was told by the PO that the 350 in my 71 was rebuilt about 30k ago. I was thinking that a synthetic my help extend the life of the engine, but I wanted to see what you guys thought first. I dont think I need the highmiles blend just a normal synthetic.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
04-05-2005, 11:38 AM | #2 |
i use mobil 1 wouldn't think of useing anything else unless i had a leaker. also synthetic in the trannys and rears
04-05-2005, 12:11 PM | #3 |
I have owned several high performance turbo charged vehicles (very oil sensative) and mobile 1 is by far the prefered synthetic.
04-05-2005, 12:32 PM | #4 |
I think i heard that synthetics leak much worse than regular oils. In a rear end it will really coat the under of your truck. Don't know that for fact though.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
04-05-2005, 12:51 PM | #5 |
IMO synthetics are the only way to go. The out perform dino oil in everything but price. And with some oil analysis most find that they can extend oil changes a lot longer. Mobil 1 is not a abd choice but far from the only good synthetic. Personally I like Royal Purple.
Edit for said Red Line, meant Royal Purple.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc Last edited by 68LSS1; 04-06-2005 at 02:46 AM. |
04-05-2005, 12:56 PM | #6 | ||
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-05-2005, 01:11 PM | #7 |
Thats a good point, I have a rear seal leak, is it better to stay with a "dino oil" (lol, hadnt heard that one before) due to cost and the undercoating issue. It would make sense that the residue would be harder to remove given the synthetics coat better.
04-05-2005, 01:29 PM | #8 | |
the synthetics may it fact leak more in leaky engines due to the fact they help clean the engine and theres less sludge build up to stop the leaks
04-05-2005, 01:41 PM | #9 |
Its Magically Delicious
im sticking with dino oil ... my 350 has over 247K on it ... the only leak is the rear intake seal and that isn't major ... Can anyone suggest a good ATF synthetic ???
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
04-05-2005, 02:43 PM | #10 |
I have used SYNpower made by Vavoline in my Mustang and like it alot they also make ATF in synthetic. My engine in my GMC don't leak and it has less than 50K on it I may run synthetic in it. One thing to keep in mind is that some say if you have used dino oil in you engine and you swich to synthetic the seals were used to dino oil and synthetic leaks, don't know if that is true because I never had a problem with my 91 5.0 Mustang I bought the car with 75K miles and switched to synthetic never leaked.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
04-05-2005, 02:50 PM | #11 |
the reason engines seem to develop leaks when a switch to synthetic is made is because synthetic cleans out all the buildup and crap that the dino oil leaves behind and the old crusty seals leak. the oil doesnt ruin the seals or any of the other crap you might hear from 15 or 20 years ago when synthetic oil first came into play. personally i run either royal purple or amsoil both are among the best. mobil 1 actually bought a formula from amsoil way back when because the blends they tried were actually killing engines in the late 80's and early 90's.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-05-2005, 02:53 PM | #12 |
I've got 225K on my Monte Carlo SS, 162K on my 96 Tahoe, I have no idea how many milesare on mt truck, but rebuilt the 402 60K ago. I'm still happy using Valvoline. Don't know that synthetics will make them last any longer than what I'm doing now.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
04-05-2005, 06:10 PM | #13 |
its all about the +6 inches
buster...it's been proven that synthetics will in fact make your engine last longer.
04-05-2005, 06:15 PM | #14 |
Oh, I don't disagree, but I think I'm doing pretty good with what I'm doing, Andy. Kind of the old "If it ain't broke, don't fix it" theory.
04-05-2005, 08:42 PM | #15 |
"Ochre Ogre"
I have a 2001 suburban as my daily driver. Purchased it with 92,000 miles on it one year ago. It was using 1 qrt every 2,000 miles and had a small oil leak at the rear seal. I switched to Mobil 1 on my 2nd oil change. The leak totally disappeared and it doesn't use any oil between oil changes which I do at 5 to 6,000 mile intervals now. I'm sold on synthetics.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
04-05-2005, 09:50 PM | #16 |
Weekend Warrior
So what are say the top three choices?
Mobil1 RedLine Amsoil Royal Purple Valvoline Synpower? Castrol Syntec? Are these all pretty comparable in quality?
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
04-05-2005, 10:57 PM | #17 |
newly minted old timer
well call me old fashioned but i dont like the synth. oils. just change your oil ever 3k and dont worry about it!
the thing that comes to mind every time someone says that synth oils wont break down, or they can go longer between changes is: its not the oil braking down that causes the wear. its the particals IN the oil. if they would spend more time on better FILTERS and less with the oil, id get excited.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
04-05-2005, 10:58 PM | #18 | |
got boost?
redline is by far superior to every other synthetic available. amzoil is a relatively close second. then mobil one.& royal purple. at least in the rigorous tests i've seen. redline is not cost effective in a street auto compared to amzoil or mobil one. in all the tests i've seen mobil one tested superior to royal purple @ about half the cost! castrol syntech is an excellent synthetic as well. now for the secret you've all been waiting for; mix 20% full synthetic with 80% of regular petroleum oil,(no fossils in my oil!), will give you 80% of the benefits of full synthetic! don't believe me?call the techies at mobil! the best part of it is it doesn't need to be high dollar oil.use the cheapy wally world oil with the above mentioned oils.the sythetic oil with it's additives takes care of everything.
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" |
04-05-2005, 11:02 PM | #19 | |
got boost?
04-05-2005, 11:13 PM | #20 | |
got boost?
the contaminants & heat causes the oil & it's additive packages to break down. causing the oil to become thinner & making it less able to do it's primary jobs; lubricate, clean & cool. oil filters are limited due to oil flow demands. if we could find a way to limit the introduction of contaminants into the oil in the first place this would make the oil last alot longer. oh, you mean someone has? http://www.coatesengine.com/
04-05-2005, 11:27 PM | #21 |
What was I thinking??
For me I use Amsoil in everything. You need to watch out as there few true synthetics out there Castrol syntec is not a true synthetic. All Castrol did was refine the dino oil different/better way.
Mobil took them to court a few years back and lost. I wish I had time to find that info but I need to get to work. Maybe someone else here knows about that deal. Cethern
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
04-06-2005, 02:45 AM | #22 |
There is a odd weight that came out about a year ago that is a synthetic from Castrol but like was said Castrol Syntec is not a true synthetic. It was released to meet a European or Japanese requirement I think. I remember someone taking Castrol to court over their use synthetic also but I don't remember who it was.
There is not a one brand oil fits all engines, even when dealing with synthetics. The additive packages are different and they have a tendency to work better/worse as ascertained by oil analysis. When you see how much pressure synthetics are able to withstand, the temperatures before break down, the ability to "cling" better (i.e. cylinder walls after shut down) and the ability to go farther between changes than dino oil there's not much left to say. And I wouldn't just arbitrarily run extended changes without doing some analysis to determine how long one could go with a little safety margin built in also.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
04-06-2005, 08:48 AM | #23 |
Weekend Warrior
so many variables and so many people recommend different things.
I guess my major thing is that i have alot of money in the motor and i want it to last and run well. 396 BBC which is built for the street, will never see "daily driving", maybe run on the track 1or2 times/year. so i guess the best bet is to go with AM or Mobil 1. I looked up RedLine alst night and thier stuff is like $9/quart
04-06-2005, 12:22 PM | #24 |
And Royal Purple which I run and has led to better oil pressure and cooler running engine (on a high mileage engine switch from Mobil).
