Old 04-11-2002, 08:07 AM   #1
Nichboy
Post Engine year ?
When i bought my truck 3 years ago the guy i bought it from had put a new 350 motor in it a year earlier and he gave me the reciept for the 3 year warranty. The # on the reciept is 010067353--engine--LM1. When i am ordering parts for this engine do i use the year it was bought or just a 350 in a 71 chevy, don't want to get the wrong parts.
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 04-11-2002, 10:00 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I just pick a car that that engine was available in, and tell them that.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-11-2002, 10:24 AM   #3
Nichboy
Post
The engine was purchased in January 1998. Just tell them it's a 98 model 350 and pick a vehicle like a 98 chevy with a 350
1971 Chevy SWB
Old 04-11-2002, 10:53 AM   #4
JJR
JJR's Avatar
Post
Part number 10067353 is the GM Goodwrench universal 350 pre 1985 applications. I have not seen one recently but don't they use the old style heads that the valve covers attach using 4 bolts on the outside edges rather than the later style that attach in the center of the valve cover. If so, the engine is basically the same one that would have come in your truck originally as far as most parts are concerned. What parts are you looking to get?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 04-11-2002, 11:06 AM   #5
Longhorn Man
Post
The big question is, is a a passenger side dipstick, and is it a one piece rear main seal?
Old 04-11-2002, 11:44 AM   #6
Nichboy
Post
JJR, yes the valve covers are held on by 4 bolts at each corner and LONGHORN the dip stick is on the driver side. Is there anything good or bad you guys can tell me about this engine. I'm not in need of any parts now, just going to tune it up and change oil. Thanks guys. Any info on this engine would be appriciated
1971 Chevy SWB
Old 04-12-2002, 09:23 AM   #7
Nichboy
Post
ttt
1971 Chevy SWB
Old 04-12-2002, 10:06 AM   #8
JJR
JJR's Avatar
Post
From what I have heard they are a good engine. You will not win many races with it in stock configuration but it is a good base to build on. It uses all new components including the block. It is a four bolt main block and has I believe about 9:1 compression.
Old 04-12-2002, 12:40 PM   #9
okietruck
Post
JJR is correct. That is the GM Goodwrench Crate engine. I just put one in my 72 LWB in January. It has a 2 piece rear seal and the dip stick can be mounted on either side, it comes with a 2 plugs of different diameters to plug off whichever side you don't use. You can go to Scoggin-Dickey's webside (sdpd2000.com) and get a spec sheet on the engine.
'72 LWB Stepside
okietruck is offline   Reply With Quote
Old 04-12-2002, 12:45 PM   #10
okietruck
Post
The folks at Scoggin-Dickey said engine parts for an 82 to 85 would interchange
'72 LWB Stepside
