05-14-2005, 11:36 PM | #1 |
Active Member
33x12.5x15 on a stock 4wd with no lift?
will these tires fit on a stock 72 4x4 with no lift without cutting or any other adjustments? thanks
05-14-2005, 11:44 PM | #2 |
I moved this here...... Theres a thread about this not that far back about the same thing you are asking. The guys that will answer you over on that forum will answer ya here if you cant find the thread I'm talking about.
05-14-2005, 11:44 PM | #3 |
I make Models
I am running those tires on mine.....
with no lift....stock suspension.....Paul K
05-14-2005, 11:54 PM | #4 |
check out this thread....
http://67-72chevytrucks.com/vboard/s....php3?t=143107 There are several threads about tire/wheel combos. |
05-14-2005, 11:59 PM | #5 |
Active Member
Thanks guys, this is why i love this board.
05-17-2005, 11:55 PM | #6 |
PROJECT 7DEUCE
I got 32x11.50 's on my blazer all stock and no rubbing issues..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-18-2005, 12:59 AM | #7 |
I ran 33 12.50s on my 72 and would have issues actually at the rear and not the front. The front corner of the rear wheel wells would hit on rough bumps. I believe only an issue with 10" wheels but not 8".
The lid is stuck on my jar of anti seize |
05-18-2005, 09:30 AM | #8 |
As long as you use 8" rims they will work. There is a guy on here ChevyDude and I have seen his K10 in person he runs BFG T/A's 33X12.50 on 8" rally rims and it looks great they really fill the fenders wells up
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
05-18-2005, 10:51 PM | #9 |
I don't have a 72, but I have an 85 K10 with 33x12.5" tires with stock GM springs except for 1-ton 3 leafers in the front, brings front level with the back, half tons in the back, and running them on 15x8s with 3.75" backspacing and no rubbing issues as of yet.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
