05-15-2005, 10:30 PM | #1 |
engine swap question
I have a 1970 model gmc ton with a straight 6 292 engine that my grandad gave me, and am trying to fix it up. My question is what parts do I need to bolt a 350 into the truck and use the factory four speed with granny first. I have the mounts and manifolds for the engine, but really wanted to know about the bellhousing and if I need to change it, and anything else I may have looked over like clutch linkages ect
05-16-2005, 07:19 PM | #2 |
come on guys, somebody has to know
05-16-2005, 09:24 PM | #3 |
Questionable
It should bolt right up.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-16-2005, 09:38 PM | #4 |
Thanks I put the engine up in parts forum, but if I can't find any takers I will try it and see, thanks a lot. I did a 6 to v8 swap in a 77 camaro with a turbo 350 and didn't change anything, but didn't know about the manual tranny.
05-16-2005, 09:41 PM | #5 |
Questionable
If all you're doing is swapping the engine and they're both older model engines, I've had several people tell me it's a bolt-up job if you have the right mounts and the number of splines on the tranny are the same. You might mount to a diff't spot (the L6 and V8 engines use different mount points on the frame, I'm pretty sure). You can probably use the existing bellhousing. Hell, I just got a 4spd manual tranny from an '84 van or something and it bolts right up to my bellhousing for my 3spd saginaw tranny.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 05-16-2005 at 09:42 PM. |
05-16-2005, 10:03 PM | #6 |
thats what I needed, thanks, I believ I will make the swap thanks a lot that was very helpful
