Old 05-16-2005, 11:44 AM   #1
motocrosschump
Some questions...??
I have a 69 Straight 6 Motor
After letting my truck warm up you can hit the gas and it will bog down then rev. I have replaced the plugs, points and condensor. I also had the carb rebuilt. What else could it be. All the vacuums are hooked up. The truck hadn't ran in 21 years before I bought it. My friend lost my feeler gauge and we kinda guessed on the points opening. Do you think that could be the problem? Plug Wires? Something else?
Next Question:
I have a three speed on the tree, If I buy a kit to put it on the floor, will it work with a 350 that I want to put in it?
Next Question
I want to put a 350 in it. Will the Bellhousing on the 6 bolt up to the 350?
Next Question:
Is a power steering conversion pretty difficult? Does anyone have a step by step?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 05-16-2005, 11:59 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i would buy a set of feeler gagues and make sure that the points where right. when my carb went out i bought a rebuilt one with a 2 year warrenty. i exchanged it 4 times in that 2 years. i didnt have good luck with those single barrel carbs. have you tuned your carb???
Next Question:
the small blocks mount in a different spot that the I6s do so that will move the tranny. you can put the 350 in the I6 mounts but then it is closer to the firewall and makes those back two plugs and any dizzy work a PITA. i would wait to put a floor shift kit in till you know where the tranny is going to be placed. there are people on here that can help you adjust your 3 speed linkage if it isnt working right
Next Question
i THINK they have the same bellhousing
Next Question:
on a 69? it is easy. box, pump and brackets. unbolt and rebolt. the hardest thing will be getting a hammer and smacking the colapsable shaft up alittle if you have all your sheet metal on still. oh yeah and if you plan on doing this while you still have the 6. it might take some lookin to find the brackets
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-16-2005, 02:09 PM   #3
motocrosschump
You my friend are the man!!
Can anyone confirm the bell housing?
Old 05-16-2005, 03:48 PM   #4
68w/sbc406
68w/sbc406's Avatar
i will. i now remember one of my friends mating a 292 to a th350 in his uncles truck
