Member since 2000
What does it take to rebuild a rear-end
The Story:
My Brother gernaded the rear-end in the 1996 burben 10-bolt? The issue: The quote to fix is about 800 dollars The point: Rather fix it myself then see 800 dollars go byebye. The question: what do i need to know and are there any special tools for the job that must be on hand before. I've done bearing changes but never done a complete over haul of a differential. So any advise/education/thoughts/prayers would be great |
you need a dial indicator with a magnetic base possibly some different shims
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: May 2002
Ring and pinion setup is fairly critical. I've never done this...so I think I would not
attempt it unless I knew somebody who was experienced at doing this. Just a thought... If the chunk was "grenaded", isn't it possible that the axle shafts were damaged also. Why not go to a junk yard and see if you can get a complete rear axle (probably for a lot less than $800). Just a thought. Jim Mt Juliet |
I am fairly "mechanical" and a toolmaker by trade,but I took mine to a pro to have it done.I think that maybe I could have done it but after researching the job,decided against it.Just my .02cents worth
As a mechanic I would say have a shop do it, I don't even do my own, I have my buddy that used to rebuild rears at a Chevy dealership do mine. I help but I let him run the pattern and set backlash, pinion preload, etc.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Member since 2000
yeah, I had someone once tell me it's a skill to build a rear-end. thanks everyone. I guess if I ever build a diff it'll be in a car i can car less if it went off a bridge.
