Old 05-18-2005, 07:32 PM   #1
Striker169
Car O'Holic
Striker169's Avatar
Body Mounts
How do the body mounts on the cab put together? I have the round rubber pieces and then these cone looking ones and the bolts and washers but how is it all susposed to piece together?
Striker169 is offline   Reply With Quote
Old 05-18-2005, 07:56 PM   #2
JimKshortstep4x4
Talking
I am not sure how your kit is set up, but the round doughnut sets onto the frame mount with the protrusion down through the hole. The large washer goes on top of the doughnut. There should be a spacer (pipe) that fits into the doughnut and the tapered rubber part fits over the spacer with the small end down. When installed the two pieces of rubber sandwiches the frame mount so the large doughnut is on top and the tapered rubber is on the bottom.
On the rear mounts the bolt screws into the body from below through the setup with the smaller washer on the bolt.
On the front mounts the bolts go through the floor and through the mounts and there should be a nut for the bottom end along with a washer.
Jim
Old 05-18-2005, 08:23 PM   #3
Striker169
Car O'Holic
Striker169's Avatar
Jim
Thats exactly what I needed to know THANK YOU SO MUCH!
Old 05-20-2005, 01:09 AM   #4
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
Got it mounted yet? Did you end up switching to the high hump?
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 05-20-2005, 10:54 AM   #5
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
doughnuts.........sandwiches.........I'm getting hungry
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 05-20-2005, 05:51 PM   #6
Striker169
Car O'Holic
Striker169's Avatar
Nah with the mounts we didnt end up needing to go high hump and I mounted it yesterday I am gonna fix the distributer today and get all the wireing out of the old cab and the glass today/tomorrow so hopefully I can drive it around the block by saturday evening.
