Old 05-18-2005, 09:20 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Pictures of tuned port injection fuel lines
Finally plumbed up the tank bought from Fuel Cell Guy for the tuned port injection.....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-18-2005, 09:22 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
every one needs a lift like that
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-18-2005, 11:00 PM   #3
skid
Nice, how big is the tank (gallon wise)?
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 05-18-2005, 11:40 PM   #4
72MARIO
72MARIO's Avatar
Thanks for the pics.
I ran my fule line last night SS 3/8" one long piece right to the pump. I used the same line claps too. I need to pick up my braded line and AN fittings that will conect the tank to the hardline. Cant wait to get out from under there.
I also just finished the 2 rear lines that go from the Felx line to the wheel cyl. The I ran the line from the master cyl to my adj porp valve. Well the porp valve not a 1/4" in for some reason ...... I will have to call the race shop tommorow and find out what went wrong.
I was kinda lost as to where to run the front lines and Now I see exactly where to run them. At least I will have thoes to run till I figure out what up with the porp valve.
Looks like our trucks are at the same point of progress only I have the box on. Is yours painted yet ?
Later, Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-19-2005, 08:32 AM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
Later, Mario
Yeah, it's painted. I took the box off to make it easier to get to the lines. I'd like to see pictures of your proportioning valve when you get it installed. That's what I have to do real soon. I hope to be able to fire the engine this weekend and break it in. Unless you just want to run braided lines to the tank I would highly suggest the Aeroquip push on barbed fittings that take two seconds to put together and are rated at 250 PSI.
See ya', Greg
Just Passin' Thru
Old 05-19-2005, 09:31 AM   #6
86swb
Born a Chevy Man
86swb's Avatar
Love the set up.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 05-19-2005, 11:18 AM   #7
iluvmy72
very nice job man....one of the best I've seen.....some people should do this for a living and you are one of them.
iluvmy72 is offline   Reply With Quote
Old 05-19-2005, 12:41 PM   #8
MikeS
Active Member
MikeS's Avatar
Nice job on the plumbing. I'm gathering up the parts to do the TPI swap this summer. I was actually thinking about running the lines down the driver's side. Looks like it'll work pretty good. Can you post part #'s for the tubing and fittings that you used?
I'm sure I'll be in touch to get pointers on installing this thing.
Mike
MikeS is offline   Reply With Quote
Old 05-19-2005, 01:14 PM   #9
71swb4x4
71swb4x4's Avatar
Holy Crap!! You pictures just made me realize I forgot one thing on my TPI swap...a fuel filter!!! How stupid is that????
Well thanks for the pictures, I know what I'll be doing this weekend.
I ran my lines pretty much the same way. I went with steel the whole way up to the front, and then did the barbed fitting with hydraulic hose on the front from the frame to the engine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-19-2005, 02:05 PM   #10
meathead95
computer illiterate
meathead95's Avatar
where did you get the line and fittings?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-19-2005, 06:38 PM   #11
72MARIO
72MARIO's Avatar
I will get pics of the adjustable pop valve this weekend. I kinda want to run the braided line it looks trick. I have a rear sump on my tank so it is visiable. It's got to look trick.
Don't you like how dusty everything gets ?
My truck is covered right now. Got to wash it so I remember how it's not in primer anymore. I need to be careful around it and not lean stuff on it.
Later,
Mario
2005 TAHOE DD
Old 05-19-2005, 07:21 PM   #12
71swb4x4
71swb4x4's Avatar
Meathead, I used steel brake line, and I had a board member flare the correct ends for me.
Old 05-19-2005, 08:32 PM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks for the compliment but I'd starve to death if I did this for a living, I'm wayyyyyyy to slow.
Just Passin' Thru
Old 05-19-2005, 08:35 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
From a local speed shop but Summit has them too. Earl's, XRP & Russell makes the AN fittings, Aeroquip for the Socketless barbed fittings and Aeroquip or Gates for the special Socketless hose.
Just Passin' Thru
Old 05-20-2005, 01:17 AM   #15
Ackattack
Ackattack's Avatar
I'll probably be running my fuel lines this weekend
Nice work!
Ackattack is offline   Reply With Quote
