Old 05-18-2005, 11:21 PM   #1
knight_182
Gauges
I want to put in some differnt gauges in my 67 C20, some ones i found off of Jegs.com, but i was wondering how hard its gonna be to take out the old cluster and put in the new ones, they arent a cluster, they are all seperate circular gauges. Appreciate the help, thanks
-A to the K-
knight_182 is offline   Reply With Quote
Old 05-19-2005, 12:26 AM   #2
Mudder
Mudder's Avatar
You can find info in the FAQ or on the main board. Really depends on what you are really wanting to do. Here's mine. It was really pretty easy. Time consuming connecting everything.
Mudder is offline   Reply With Quote
Old 05-19-2005, 12:28 AM   #3
Mudder
Mudder's Avatar
Gonna move this to the main board so you'll get more responses.
Old 05-19-2005, 09:45 AM   #4
Putter
More Cowbell....
Putter's Avatar
Here are mine also.
I have mine set up a lot like Mudder (actually, I almost copied it). I installed them from the back instead. He is right, it will take a little time to do, depanding on how nit-picky you are with the back side of it.
(**notice I even made up a quick connect harness**)
As far as getting your old cluster out, just remove the knobs for the headlights & wipers (and choke if you have one), unscrew the speedo cable from the cluster, unplug the harness, remove the screws, and voila....it's out. I did have to drop the support for the steering column and let the column drop so I had a little more space to work with, but I have done it without moving the column, also.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-19-2005, 02:22 PM   #5
knight_182
ok
yeah that helps, were did u guys get ur gauges from and how much did u pay for them
-A to the K-
Old 05-19-2005, 02:41 PM   #6
Ackattack
Ackattack's Avatar
I got mine from summit, but I don't remember how much they set me back total. I also made a quick disconnect using some trailer wiring harnesses.
Ackattack is offline   Reply With Quote
Old 05-19-2005, 03:05 PM   #7
Putter
More Cowbell....
Putter's Avatar
I got mine from Summit & Jegs. Not exactly cheap, by any means. I could have bought a new tach dash from any of the vendors for less money.
I dropped $573 for the gauges, then had to add the cost of a new bezel, plus several hours of fitting & wiring.
Old 05-19-2005, 04:11 PM   #8
Mudder
Mudder's Avatar
Mine were around 500 bucks for all the gauges. I had a new bezel. I think its one of the nicest things I have done to my truck. IMO. Having good accurate gauges is pretty nice. If you look around the site there are all different kind of options that u will see.
Old 05-19-2005, 07:57 PM   #9
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
so electric or mechanical?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-19-2005, 08:14 PM   #10
Mudder
Mudder's Avatar
I say go electric but its probably to everyones opinion as to waht they like. I think the electric was pretty simple. I did get a mechanical speedo.
Old 05-19-2005, 08:59 PM   #11
68Stepbed
68Stepbed's Avatar
Putter and Mudder67, what size are the gauges in the middle hole? I want to set mine up that way but haven't seen any that fit.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-19-2005, 09:23 PM   #12
Mudder
Mudder's Avatar
The middle gauge is 3 3/8. Autometer doesn't make the black face anymore. They still make the 3 3/8 water and oil pressure in teh phantom series. (white faced).
Old 05-20-2005, 09:16 AM   #13
Putter
More Cowbell....
Putter's Avatar
The reason mine was a little more costly was I chose the electric speedo. The sending unit is seperate, and that makes up most of the cost difference. But, I just swapped rear axles with GMan69 so I could get his 3.07 gears (I do interstates alot), and with the electric speedo, it took literally 4 minutes to re-calibrate my speedo, and I never had to get out of the cab. It kinda eliminated the trial & error portion of speedo calibration.
I absolutely love my gauges and feel they were worth every single penny.
Old 05-20-2005, 12:15 PM   #14
Lemield
Lemield's Avatar
Putter....Those look awesome! Great job.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
