05-19-2005, 06:28 PM | #1 |
My son, my joy.
Driveline carrier bearing
I remember people talking about carrier bearings but I can't seem to find the search function.
I keep having to replace mine. I have a feeling it's an installation issue. Is there a trick to getting them in there just right so they don't go bad in a couple months?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400. Founding member of the No Money To Spend On My Truck Club. When your at Home Depot, you WISH you had gotten an 8 foot bed! |
05-19-2005, 08:08 PM | #2 |
December 21, 2012
Take it to a machine shop and have it pressed on by them. Also you might make sure your driveline is balanced as an unbalanced driveline will tear a bearing up pretty fast. Prices will vary from place to place but here I got the bearing pressed on for $10.00 and the driveline balanced for $30.00. Probably higher now. I havent had a problem with it sense and its been probably over 12 years now. At one point I was going through a bearing every couple of years.
"!Ama Sua, Ama Kjella, Ama Lllulla!" Last edited by Maximum Overdrive; 05-19-2005 at 08:09 PM. |
05-19-2005, 08:16 PM | #3 |
The other possibility is the rear is not centered. That was what caused mine to go out the first time (PO put front coils on the back, raised it a good 3"). When I put the rear back together I put in a billet one from DLS.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-20-2005, 11:29 PM | #4 |
My son, my joy.
Thanks for the advice. A guy at the parts store suggested that it could also be the tailshaft bushing in the tranny. I'm told they rarely wear out, but I did have one go bad on me in a previous Chevy vehicle.
