Old 05-21-2005, 03:25 PM   #1
1987SierraClassic
Power Window Issues
I have an '89 Suburban and the right rear window works intermittently. When testing, I can hear the motor try to move the window up (already closed), but no action in the down position. I'm wondering if there are limit switches in there somewhere that stop the motor when the window is all the way down or up and perhaps the motor thinks that the window is all the way down.
Anyone got any thoughts? New motor time?
1987SierraClassic is offline   Reply With Quote
Old 05-23-2005, 07:17 PM   #2
hotrodhomi
hotrodhomi's Avatar
check the switch
hotrodhomi is offline   Reply With Quote
Old 05-24-2005, 05:36 AM   #3
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
There's no limit switch or anything, I would do as suggested above and start at the switch.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 05-28-2005, 06:32 PM   #4
1987SierraClassic
I tried the door switch, no luck. The only thing I haven't tried is replacing the 4-position switch on the driver's door since there is a feed-through on that one. I'll try to pickup a used one for testing. I'm just trying to avoid the hassle of replacing the motor if I don't have to!
Thanks for the info!
