Old 04-12-2002, 11:52 AM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post 700R4 kickdown bracket
What vehicle should I get one off of? I have an edelbrock performer intake and don't know if there is a certain one that would fit better or not.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-12-2002, 11:56 AM   #2
tom hand
CCRider
tom hand's Avatar
Post
http://www.tvmadeez.com/Installation.htm
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-12-2002, 08:45 PM   #3
Reumster
L.E.D. Freak
Reumster's Avatar
Post
I got mine down at AutoZone.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 04-12-2002, 08:59 PM   #4
LAP
Post
Bowtie Overdrive sold me a TV cable kit and bracket. The bracket was the same one for the turbo 350 cable! The transmission guy told me to send that sh$# back and he pulled out a universal cable and used the old turbo 350 bracket. He then attached it to to the carb where the old trans cable connected. He drove it down the road. Stopped, made an adjustment, and then sent me home.
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
Slaughter, La
LAP is offline   Reply With Quote
Old 04-12-2002, 11:14 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Hmmmm, you might want to have it looked at by a more reputable tranny guy. That isn't the proper way to set it. Need pressure guages hooked up to the tranny.
The TV cable controls the amount of oil psi inside the tranny.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-12-2002, 11:48 PM   #6
'72 Cheyenne Super
Post
Longhornmail is absolutely right. The "factory" TH350 bracket and mounting stud on the carburetor is not positioned appropriately for the TV cable to work properly. You will need to move the cable mounting stud to a position which gives you immediate pressure rise as soon as the throttle begins to open, and pulls to full extension at WOT (but not so it stretches the cable, or resets the cable housing adjustment). You'll know if it is adjusted properly with the aforementioned pressure rise as soon as you depress the throttle pedal, and if it will do a 2 gear downshift (yes, two gears!) to first while rolling along slowly in 3rd gear. It will take a little trial and error to get the mounting stud in the correct position.
'72 Cheyenne Super 4x4, 468ci, 700R4, Import Stomper.
A couple pics at http://www.picturetrail.com/gallery/view?p=6&uid=529895&
'72 Cheyenne Super is offline   Reply With Quote
Old 04-13-2002, 08:21 AM   #7
gmtruck71
xwrench2003
Talking
The cable does control line pressure inside the unit and djustment MUST be correct to eliminate tranny damage. Depending on your carb type, TPI makes a small bracket that bolts to the throttle lever of Holley carbs, it positions the cable mounting stud in a way to provide the proper line pressure throughout the entire throttle range. I have used this configuration for 4 years with no problems. Good luck
Marty Hall
Taylorsville, Ky
1971 C-10 SWB fleetside (355,700-R4)
1971 K-10 LWB Cheyenne (454\turbo-400)
1972 C-10 SWB stepside (6-cyl)
1949 3100 chevy panel delivery
(original)
93 S-10 Blazer
93 S-10 Pickup
Marty Hall
1971 K-10 LWB Cheyenne (461\T-400)
93 S-10 Blazer (330,000 and still going)
86 SS Monte Carlo (40,000 miles)
85 Chevy Scottsdale
02 Jeep Liberty
gmtruck71 is offline   Reply With Quote
Old 04-13-2002, 09:02 AM   #8
AZ68
Post
got mine at hi-po shop in town fits with my edelbrock ---- runs great cable and bracket about 25.00- 35.00 make sure you set it correctly---- the one I have has a ratcheting type do hickey for adjustment -- install everything then unclick lock full to just short of full throttle then lock down should work fine --
68 c-10 lwb to swb 383 lr stroker 700 r4 starting frame off now
phoenix, arizona
AZ68 is offline   Reply With Quote
