Old 06-19-2002, 07:54 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Question What gauge size?. 2 1'16"
Hey guys,
I'm thinking of replacing my bottom row of gauges with Auto Meter mechanicals. Are the 2 1/16" a direct fit?. Also how would a clock be wired up in our trucks?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-19-2002, 08:03 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Not sure of the size, but the sun pro tripple guage set that you can get at auto zone fit right in there. As for the clock, just run a wire to a full time 12 volts...fuse box should be fine for this.
Old 06-19-2002, 10:53 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Thanks Andy!,
Most of the triple sets are 2 1/16" so I should be ok.
BTW- I hope your new job is going good!
Jim
Old 06-19-2002, 11:07 PM   #4
racedvl
racedvl's Avatar
Like this?
racedvl is offline   Reply With Quote
Old 06-19-2002, 11:09 PM   #5
racedvl
racedvl's Avatar
Also I have a clock now installed, and it doesn't even need to be wired!!!
Old 06-19-2002, 11:59 PM   #6
Longhorn Man
LOL! I think I like the clock that was in my old Longhorn better...
Old 06-20-2002, 12:01 AM   #7
Longhorn Man
The job is going OK, thanks for asking. Little crappier than I remember, but it'll do for now.
Old 06-20-2002, 12:07 AM   #8
Zkast
Zkast's Avatar
I put a set of VDO gauges in the bottom.. mainly so I could get a decent looking clock in there
Zkast is offline   Reply With Quote
Old 06-20-2002, 08:03 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Your gauges kick @ss!. Racedevil, your tach is sweeeeet. Was it hard to install?. Zkast, where did you get VDO gauges?. That's the exact look I'm after.
Jim
Old 06-20-2002, 12:19 PM   #10
WB72
Before and After
WB72's Avatar
What size tach would it be for the center gauge?
Are the original sensors and wiring still usable?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-20-2002, 05:10 PM   #11
Longhorn Man
No, you have to use the sensors that come with the guages. You can't even use the dash lights.
Old 06-21-2002, 01:00 PM   #12
70c10
67-72 Addict!
70c10's Avatar
wHY CAN'T YOU USE THE HEADLGHTS?
Jim
Old 06-21-2002, 01:55 PM   #13
Frank_Zeller
Frank_Zeller's Avatar
Autometer sport comp 2 5/8
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 06-21-2002, 02:34 PM   #14
Longhorn Man
You could use them, but a real pain to wire up.
Old 06-21-2002, 10:24 PM   #15
racedvl
racedvl's Avatar
70c10, the tach fits tight in the factory bezel. One member actually mounted behind the factory lens. I dunno who it was though.
Old 06-22-2002, 12:19 AM   #16
Zkast
Zkast's Avatar
I bought those 4 lower gauges from Napa if I remember right...
Gas gauge is out of a 81 LeSabre and then the monster tach. Tach slid right in, I was amazed at how close it fits.
Although I did hack my I/P up pretty good. I wired in new lights and wiring harness for it then installed a 15pin bulkhead connector for the body harness. All that because I wanted a clock and a tach lol.
