06-22-2005, 01:18 PM | #1 |
replacment body mounts
hey guys i am getting a free 85 suburban. it needs body mounts all around and 3 need some metal. where the body mount goes
where can i get replacment panels so i can weld these in? |
06-24-2005, 04:33 PM | #2 |
Too many projects!!!
Mike,
I'm in a similar situation with my 89. Several of the body to frame mounts are rotted out on the body side. The frame is not in bad shape..it has rust..but no rust through. As far as I can tell..nobody makes any replacement panels for the supports. So I am looking for another burb tub. Sean
Sean 1995 Buick Roadmaster Sedan 2004 Chevy Trailblazer 5.3L V8 1963 Chevy Biscayne 4D Sedan 1971 Chevy C10 (now have 70 cab & frame) 1968 Chevy C10 (parts for the 70) 1991 Oldsmobile Custom Cruiser (Chevy 355 motor) 1937 Pontiac 8 4D Touring Sedan (in pieces) Jacksonville, Florida |
06-24-2005, 10:01 PM | #3 |
Tonawanda 454
http://www.lmctruck.com/ has panels, i have their catalog here too, from the 2005 Spring catalog it is page 27 from the burb catalog.
i think JC Whitney has them too and i am sure plenty of other cuppliers have them too but i am not sure of the quality of them
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
06-28-2005, 08:43 PM | #4 |
Screwball,
I have the catalog too, I know they make "body panels" for the exterior..but what they don't make are basically what I would call "cab" mounts. I think that is what Mike is talking about...and I know that's what I would need to save the burb body on mine.
06-29-2005, 05:51 AM | #5 |
Truckless for the moment...
When I did mine this past March, I needed two brackets that mount on the rear of the frame. Nobody makes them, not even GM, so I fabbed my own.
It sounds to me like you're looking for the metal that's attached to the body though, which apparently nobody sells either. A couple of mine were rusty, and I need to fab some up eventually. I suppose, at this point, swapping a new tub onto mine wouldn't be a bad idea....
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now... |
