Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 08-03-2005, 06:49 PM   #1
68_Steps
68_Steps's Avatar
n00b- 68 Stepside: Central FL
Hello all,
Just wanted to get my foot in the door here, I've browsed tons and posted once but thought I should add into the n00b pages. As above, I normally drive a '68 stepside, needs a bit of work, but that's just fine with me. Unfortunately there won’t be much build-up on the truck for the next couple of months as I am currently in the Arabian Gulf supporting Marine operations. I'm posting a few pictures along with this so let me know what you think.
Craig L.
/\ when I first got the grey clunker
/\ After a little TLC, posing in front of my current home USS Kearsarge
68_Steps is offline   Reply With Quote
Old 08-03-2005, 07:14 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Looks a lot like my '69. That grille looks good. What happened to the '68 front clip?
Frizzle Fry is offline   Reply With Quote
Old 08-03-2005, 07:30 PM   #3
68_Steps
68_Steps's Avatar
Well honestly, what I was told and what the old title said was that it was a 68, but the front clip and the fact that the front disc brakes look stock and all the other little things, I believe it's a later year than it's registered as, or pieced together from a couple of trucks
Old 08-03-2005, 07:53 PM   #4
arkracing
Weekend Warrior
Looks like the front was lowered so they may have swaped out the original front drum spindles to lowered disc spindles...
it's a '71-'72 front end from the looks of the grill in the first picture and the front bumper
where is the e-brake? is it a pedal or a handle? rear view mirror?
could be an older cab with new nose/front end parts like you said... sill a nice looking rig
and stay safe over there
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 08-03-2005, 08:02 PM   #5
68_Steps
68_Steps's Avatar
The e-brake is below the steering column, handle type and the rear-view is mounted in the headliner and not on the window. If i could find a copy of my registration and decode the VIN, I could probably get some kind of idea... I'll do my best to keep my head above water. Good lookin' out.
Old 08-03-2005, 08:15 PM   #6
Frizzle Fry
Sounds like someone swapped the front clip. Looks good though. My '69 is a compilation of multiple trucks (even has some Suburban parts).
Old 08-03-2005, 10:17 PM   #7
arkracing
Weekend Warrior
Yeh - sounds like the correct cab with a front clip and suspension swap.
normal for these trucks.
mine has parts from a whole bunch of stuff - 1973+ Front Steering and suspension, '72 Hood, '69 Cab/Frame/Clip/Bed/RearEnd, '85 Motor, '88Trans etc etc. Still looks good to me.
-'66 C10 Suburban
Old 08-06-2005, 01:12 AM   #8
TRUCKGUY
TRUCKGUY's Avatar
welcome to the board from western ky
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
