06-28-2002, 02:08 PM | #1 |
found an engine! now what else needs to be checked/replaces while new engine goes in?
allight found a chevy dealership who will sell me the goodwrench 350 motor for $1420 + $100 core charge, and ive got a guy installing it for $500.
now what else should i be checking or replacing while the new engines going in? i was going to have the radiator sent out to be pressure tested etc, getting a new water pump, what else do you guys suggest? i just did a tune up on the ignition system (new plugs wires coil cap rotor) so im thinking im only going to buy new spark plugs since theyre probably gunked up with oil in the two months theyve been in. |
06-28-2002, 02:18 PM | #2 |
Recovering Truck Driver
plugs, heater hoses, radiator hoses, fuel pump, check all your vacuum lines for cracks or weathering.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
06-28-2002, 03:01 PM | #3 |
Why is there a core charge on a crate motor? They sell them outright. I didn't pay a core charge when I bought mine.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
06-28-2002, 03:43 PM | #4 |
What transmission do you have? Inspect the fly wheel, front seal, etc. If manual check the clutch and throw-out bearing.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-28-2002, 05:42 PM | #5 |
Somebody is pullin' your leg. I was just quoted 1350.00 for a crate motor, outright, no core. You might want to think about your starter, specially if you are running headers.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
06-28-2002, 06:01 PM | #6 |
Now is a good time to paint the engine compartment.
Mario
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
06-28-2002, 06:16 PM | #7 |
Formerly yellow72custom
If you are buying the brand new GM 350 Goodwrench motor, why would
there be a core charge? If you are buying a remanufactured motor there should be. If it is a reman, $1450 sounds a bit high for me. I would talk to the guy again and see which engine you are getting. I would install all new belts, hoses, thermostat, water pump, and check the starter teeth on your flywheel. If they are worn, a new ring gear or flexplate dosen't cost very much, and it will be easy to install when the engine is out of the truck. Like WORNBRAKES said, clean the engine compartment really good and give it a coat of spray paint so it will look a little better. I would go ahead and clean all of your engine brakets, accessories, intake, and whatever else for a fresh look under your hood. Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
06-28-2002, 08:57 PM | #8 |
well as for someone finding it for $1350, im sure there will be different prices everywhere (scoggin dickey was $1475) id rather pay $1420 since this is a local chevy dealership and if anything goes wrong witht he motor the will cover the parts and labor. the engine i was quoted for is the gm goodwrench crate 350 with 3yr/50k warranty and it is a new engine, im not sure why they want the core charge but ill get back to you when i go there monday.
06-29-2002, 09:46 AM | #9 |
If it is a standard shift a pilot bushing from a old model diesel is a roller bearing, and can be perchased through your chevy dealer.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
06-29-2002, 01:54 PM | #10 |
Thats the Hillbilly way
Did anyone mention Motor Mounts ?
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
