Old 09-12-2005, 10:13 PM   #1
NZCP
Question 2WD Blazer/Jimmy Wheel Backspacing Question
Hi there
I want to order some wheels for my Jimmy that I have bought.
What backspacing do I order?
I am in New Zealand so I have no way of measuring this.
I look forward to your replies.
Clive
NZCP is offline   Reply With Quote
Old 09-13-2005, 08:52 PM   #2
Big Block
Big Block
Big Block's Avatar
What year blazer do you have?
Big Block is offline   Reply With Quote
Old 09-14-2005, 01:56 AM   #3
NZCP
Year is 1979
1979- I need to get this sorted out so I can order my wheels and get them into the truck before it ends up in a container.
Old 09-14-2005, 06:50 PM   #4
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
backspace depends on alot of things, width of wheel? size of wheel? stock height? slammed? tire size?
milehightoyz is offline   Reply With Quote
Old 09-15-2005, 08:14 PM   #5
NZCP
backspacing
Probably looking at either 15 or 16" X 8
Suspension has been dropped 3 inches
Tires will be 235 wide
Old 09-15-2005, 10:07 PM   #6
milehightoyz
if you used 3" drop spindles and want to run 15's you are gonna need a really negative offset (3" backspace or less) or you are going to need to grind your lower control arms down. 16x8 or larger you should be fine with 4"-4.5" backspace or so.
Old 09-17-2005, 06:42 AM   #7
NZCP
Will these be ok?
It currently has 15 x 8 Ralley's on but I want to put Eagle Wheels series 203 which at 15 X 8 has 18mm negative offset and 3.75" backspacing.
What do you think?
i know the springs have been changed but am unsure if it has drop spindles.
Old 10-04-2005, 09:12 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Turn your wheels all the way one direction and take a look. You might need a flashlight, but you should be able to see the spindles. Most aftermarket manufacturers will cast their name in the spindle. If they are stock, they should have GM on them somewhere....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-09-2015, 08:05 AM   #9
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 2WD Blazer/Jimmy Wheel Backspacing Question
Bringing this back up. Looking at either 18" or 20" wheels. (NOT 18 front / 20 rear)
18x9 with 4.5" back spacing
20x9 with 3.75: back spacing
Rich
1972 K5 Blazer CST Click HERE
