Old 07-03-2002, 12:22 PM   #1
darrel_s
darrel_s's Avatar
Blazer Poly Tanks?
Have the original steel tank in my Blazer with couple of pin holes in it.
Better to spot weld it up and pour in some tank sealer, or buy a replacement poly tank?
Anyone bought one. Opinions?
darrel_s is offline   Reply With Quote
Old 07-03-2002, 12:25 PM   #2
Low69CST
I have a poly tank. I'm gonna use it, but I think it sucks. you can't get the vent fittings started straight in the plastic, theres always the heat and puncture issue too.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-03-2002, 12:35 PM   #3
darrel_s
darrel_s's Avatar
Thats what concerns me. I've seen one guy that had a tank with one side pressed in. Looked like it was imploding due to incorrect venting or something. I take it that they are not very thick. What are the issues with the vent holes you mentioned?
Old 07-03-2002, 12:47 PM   #4
busterwivell
I would call Wes.......that's where I got my poly tank.......If you decide to try and weld your tank.......well, we'll talk to you in the next life. I'm betting the guy with the shrunken tank plugged all the vents. There is something to be said for doing it the RIGHT way!
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 07-03-2002, 01:04 PM   #5
darrel_s
darrel_s's Avatar
Not Hindu, but thanks for the concern. Although I'm sure someone somewhere in the past has actually tried it.
The tank has been out of the blazer for awhile now. So hopefully the only bright light I will be seeing is the spot weld.
My only concern with repairing the old tank is how long and how well the tank sealer actually works.
Old 07-03-2002, 02:14 PM   #6
colohusker
Doesn't matter how long it's been out, you'll still get vapors in it from any residue in it. The best way is to fill the tank with co2, either from a bottle, or by putting some dry ice in it before you weld it.
Scott
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 07-03-2002, 02:23 PM   #7
Low69CST
Sometimes radiator shops will also work on gas tanks too. My dad has welded up gas tanks for small engines. You can do it if you just practice saftey, but I wouldn't want a career welding gastanks.
Old 07-03-2002, 03:11 PM   #8
Mixup
I have a poly tank in my pickup and it IS vented and it IS collapsing on one side.It will be over 105 here in the desert for about 3 months and I don't think they can take the heat. Yes most of the new vehicles on the raod have poly tanks but I think they are made alot better then that poly blazer tank.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 07-03-2002, 03:58 PM   #9
darrel_s
darrel_s's Avatar
Thanks for the advise guys. Looks like I'l stick with the old.
Old 07-03-2002, 11:38 PM   #10
NuBomb
NuBomb's Avatar
Took mine to a radiator shop and had them do the work. It was less than $100 and has worked out great. Worked out great for me.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
