Old 04-15-2002, 12:25 PM   #1
neonlarry
neonlarry's Avatar
Question Vortech Heads
I was thinking about using them and I have a few questions. Are vortech Heads something you can get from the junkyard? If so what cars/trucks would they be on? I know the intake manifold is different, but will the same lifters, exhaust manifolds, etc work? and last, if I could get a set of used ones, would it be a bad idea to put them on my old 350 without rebuilding it?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-15-2002, 01:12 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
they come on 96-98 trucks with 350s.. so finding them in the junkyard might be a little hard
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-15-2002, 02:53 PM   #3
Cheyenne Super
Post
They are pretty inexpensive from any gm performance parts dealer. Plus you don't have to worry about worn valve guides or getting a valve job, or anything else associated with buying used heads.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 04-15-2002, 03:08 PM   #4
racedvl
racedvl's Avatar
Cool
They are somewhere around $450 NEW from the dealer!! Cheap go fast goodies!! That's the name of the game!!
http://hometown.aol.com/racedvl/racedvl69index.html
Woodstock,IL.northwest of Chicago
It's not what you buy, it's what you build!!
I did not climb to the top of the food chain, to become a vegetarian.
For some pics of my truck.
racedvl is offline   Reply With Quote
Old 04-15-2002, 03:27 PM   #5
Luckymic34
Whisky Bent & Hell Bound
Luckymic34's Avatar
Post
You will also need some self aligning rocker arms to go allong with that setup
68 custom stepside PS,PB
350 with Vortec Heads,Carter 650, Edelbrock Performer,HEI,
Crane Enegizer 266, Headmen headers
40 series Flowmasters, B&M hole shot
2,000 rmp stall, TCI TH350 Streetfighter,
4.10 gears
Virginia Beach, VA by way of
Houston, TX
4.10 gears
2003 Harley Davidson 883C
San Diego, CA by way of
Houston, TX
Luckymic34 is offline   Reply With Quote
Old 04-15-2002, 04:21 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Your manifold/haders will bolt right on. You'll need new center bolt valve covers, new style intake gaskets, and the aformentioned intake manifold. The self aligning rockers can be omited for some hardened pushrods and guide plates.
Your cam selection is limited onless you are willing to replace the springs, I think it was .420 lifft, that or .480...I can not remember at the moment. Call a cam company, they will set you up with exactly what you need.
I wouldn't even bother with junk yards on this...and I'm a cheap b@stard.
As for new heads on an old engine, it all depends on how old you are talking about, and how hard you'll be pushing it. If you have 100K on the clock, I wouldn't even think of it. (not again anyways)
However, if you have 50,000 or so, I think i would yank it, inspect real close, and take it from there.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-15-2002, 07:02 PM   #7
JReynolds
Post
I've got Vortechs on my 350. Stock they can handle up to .470" lift, I had my valve guides cut down .100" anticipating a bigger cam than I actually ended up with. This would have allowed for .570". (Not that I actually considered that much lobe......) The cam I ended up with was CompCams Extreme Energy 262H. .460" intake, .469 Exhaust.
Duration at .050" is 218/224. with this cam, Edelbrock Performer manifold, ceramacoat headers, HEI ignition, and 750 cfm Edelbrock, I dynoed at 380 horsepower at 4800 rpm, and 445 ft/lbs torque at 3800 rpm. Torque stays over 400 ft/lbs from 2800 to 5500 rpm. Great street motor, used lower RPM range manifold because of my 3.07 rearend gears. This engine idles fine at 600 rpm, and I run it on 89 octane fuel. Hope this helps.
1969 SWB Stepside. 350 w/Vortec heads, 380 H.P., 450 ft/lb dyno proven.
JReynolds is offline   Reply With Quote
