Old 04-15-2002, 06:49 PM   #1
Pumkin Truck
Thats just prime!
Pumkin Truck's Avatar
Post >>>------------->69 LONGHORN<--------------<<<
Whats up longhorn, i wanted to ask you about your motor mounts when you had the 425 in there. were they fabricated or aftermarket, if so where can i find them.
thanks a lot
Pumpkin truck.
[This message has been edited by Pumkin Truck (edited April 15, 2002).]
*69 GMC short bed stepside with a wimpy six that can barely pull itself.
*99 Chevrolet Camaro Z-28
1 Bad 5.7ltr LS1
Pumkin Truck is offline   Reply With Quote
Old 04-15-2002, 07:20 PM   #2
69 longhorn
Post
I used a 73 up stand,with a 3/8" flat plate welded on top to extend foward. On top I had a bracket& clamshell mount from a 78 sed deville. My eng was also set back far enough that I had to rework the firewall around the heads.(Im a weight transfer nut!).My guess is that if you leave the eng far enough ahead for firewall clearance,you would be better off using an early 70s cad mount,& building brackets to hang off the frame ahead of the crossmember. Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-15-2002, 10:45 PM   #3
Pumkin Truck
Thats just prime!
Post
Whew!!! that is relief to hear that i WILL NOT have to slice and dice my fire wall! I just want that motor in so i am very pleased to hear you did it for weight tranfering. btw thanks for the reply.
1 Bad 5.7ltr LS1
