Junior Member
The Search has Ended. My new Burb!
Well, I waited and I found it. It's a 72' Chevy Custom Deluxe factory 4x4.
Montana truck from new till around 92'. Everything was rebuilt. 350/350 Automatic, Posi rear, Tilt, Tach (no A/C though....but not for long!) What do you guys think? Thanks to all who helped me with advice, leads, and help! ![]() |
![]() Join Date: Apr 2005
Good find! Welcome from FL.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Junior Member
Thanks. A/C question
Thanks. It's great to have "an old truck" to drive again!
It came with the factory rear A/C unit to install, and I have to find a front unit now. People suggested a Vintage-Air Unit to install. I'm not sure. It was kept all original (even the push button radio (?) ) so it might be nice to keep the A/C looking completely factory installed. What I dont know is actually how good the original A/C systems were back then. I hear the Vintage-Air type systems have been perfected, and work beautiful in these trucks. Anybody have any experience with this? |
![]() Join Date: Aug 2005
Very nice! I love the white below the trim. I plan to add that when I paint mine. The only thing I'd add on the exterior is the trim below the windows (I'm kinda partial to it). Congrats on an excellent purchase.
nice truck
![]() Join Date: Apr 2000
Very Nice!!
If convienient sometime I would like to see closeup paint picture where white top meets body color at rear corners. This is often where the upper belt mouldings resided on 2 tones. I tried once to maska line and failed. Would like to see how it is done when right. What state did you find it in?
Great ride. Hope to have mine as nice someday.
Bob |
They sure look great all gussied up.
![]() I've never made a side by side comparison, but I've heard that the original A/C system on R12 beats all the aftermarket systems in cooling temps. The aftermarket units have better fans, but I wouldn't be surprised to discover that replacement oem motors are also upgrades. AFAIK, all the aftermarket dash units draw A/C air (not heat) from only inside the cab. If you go aftermarket R134, be sure that whatever they sell you can handle the rear unit, too. For instance, the condenser might have to be larger. I don't know for sure, though. Just postulating. I'll be returning my C10 burb's A/C to factory refreshed on R12 since it is complete. A complete oem 72 CK A/C system meticulously removed went for ~$500 on ebay earlier this year. I can't remember if that came with roof air. Probably not. Get a copy of Classic Industries catalog. They have great pics of most of the serviced A/C parts on 71/72 trucks. Not great prices, though. ![]() BTW, does the truck have an A/C dash?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 10-15-2005 at 03:53 AM. |
Junior Member
Thanks again.
The Burb came out of Seattle. The fellow has had several of this era Chevy trucks over the years. He did a amature body off on it and rebuilt everything.
He towed other trucks he was restoring on a double axle trailer with it, prior to restoring it. He used a "beater" for towing after that. He was starting a 54 Convertible restoration project, and had no room, and didnt want to put it outside, so he decided to pass it on as they say. He never installed A/C as he really didnt need it in seattle. But he wanted to do it at some point, that's why he picked up the complete rear unit when he found one. I like the white on the bottom too. (it's also practical, incase a rust spot developes on the bottom, it can be fixed more easily.)The last owner was torn between installing (adding actually) top belt molding on it as well. He likes it but didnt want to start drilling holes everywhere. Thanks for all the A/C info. The Burbs sure have a lot of cubic-feet to cool off, so it has to be done right. I will get that Catalog for sure. Thanks! The truck does not have an A/C dash. (swivel "eyeball" type vents) Question: was the rear A/C ever installed as the ONLY A/C UNIT in these Suburbans? Two-Tone Paint Trick: Masking a paint line and having it "bleed" underneath can be a pain. Years back I worked for a custom paint shop, and what we did was to thumb-nail down the "fine-line brand tape" right before spraying it, But we would first spray it with Clear, and then spray it with the color afterwards. If anthing seeped under the tape, it was only the Clear. The Clearcoat can't be seen. |
Re: The Search has Ended. My new Burb!
very cooool
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
#10 | ||
Also, the molding doesn't fit closely, so it lets water pass beneath it. It does do a good job of collecting small leaves, though. ![]() Quote:
I don't care 100% about factory appearance, so I'm painting my current project burb using the factory roof seam so I don't have to have a paint line down lower on the D-pillar.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
nice burb, congrats!
Boy, that sure is pretty! Good to see more old trucks in NJ. Where abouts in NJ are you? I'm in Budd Lake (Morris county) Chris
#13 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#14 |
67 is sold
Looks like a nice clean burb, and a 4x4 to boot
#15 |
Happy to be here
![]() Join Date: Mar 2000
Very nice Burb. That was well worth the wait. You have any more pics?
#16 |
Mike
The front/rear ac set up is a 72 only option.I have seen 72 suburbans that had the front only,but never just the rear.I have a 1971 that I converted to r134a.It cools just as good as my 72 that is r12.The only thing that does not look factory on my 71 is the pressure switch.67-71 had a tunnel running the length of the roof.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#17 |
Mike
By the way,That is a real nice looking Suburban.Good luck with it.
#18 |
Very nice truck. As far as the upper trim is concerned, I agree with 4x4 poet, it is a pain. When I had my Burb painted, I removed the upper and lower trim and had the shop mig weld all the holes (there are a ton). I replaced the lower trim with the newer style Silverado-type that is self-adhesive and cut to fit. I have the same two-tone paint scheme (upper and lower white), and I think it looks great--and now I don't have to worry about all the water that used to find its way inside!
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
#19 |
Born a Chevy Man
I to have to agree. That is one nice Burb. I also never have seen one of these Burbs with a rear air only. Great find.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#20 |
Old School, New Style
Nice burb!
I have the self-adhesive lower trim that grebus1 is refering to on my burb also. I agree with not putting extra holes in the body. Buy the way, if I'm not being to forward, what did you give for that beauty? Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 10-17-2005 at 07:45 PM. |
#21 |
Looks like your search ended in the right place.Congradulations!!
#22 |
Hey Long Roof, what's the story on the missing exterior handle on the 3rd door? Also, what type of exterior mirrors are those--are they stock for your year Burb? Mine currently has the sport mirrors (like NOSguy has on his), but I can't see for @#$! out of them!
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 Last edited by grebus1; 10-18-2005 at 01:21 PM. |
#23 |
Junior Member
Thanks Special K. I KNOW your right! I love it more each day.
Good eyes grebus1. Those extended mirrors are neat. I'm sure especially good if trailering (like I'll be doing) Was that some sort of option? |
#24 |
The rear door handle was filled by the previous owner. I'm still undecided if I like it. It has no power solinoid so you have to reach in from the front door to open it. It does however match the driver side in looks.
The mirrors are factory. You can see much more than the sport mirrors but they tend to vibrate with only the one arm holding the mirror head. Later, Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
#25 |
Tonawanda 454
VERY NICE!!!
and welcome from FL.. about an hour east of the first responder here, rob...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
