10-24-2005, 09:27 AM | #1 |
67 is sold
Wanted: rear door handle for 67 Panel
I have the cargo doors on the rear of my '67 Panel truck. I am looking for a decent, usable rear door handle assembly.
The side door handles will not work due to the rear doors requiring a longer acuator piece. Anyone have one for me? Thanks, Joe |
10-27-2005, 07:27 AM | #2 |
67 is sold
Re: Wanted: rear door handle for 67 Panel
TTT
I'm handle-less... |
10-27-2005, 03:15 PM | #3 |
I may have one for you. Let me see if I can dig it up and I'll send you a pic.
TJ |
10-28-2005, 08:46 PM | #4 |
Hey if you can't find one you can use a regular right side door handle but you have to use the same button from your old on I had to do this too.
1964 BBC 402 4x4 |
10-28-2005, 10:11 PM | #5 |
67 is sold
Yeah, I already had a spare RH handle, but I need the button/lever mechanism for the rear door.
Right not I have no handle at all on my rear door. |
11-01-2005, 10:20 PM | #6 |
67 is sold
Ttt
11-02-2005, 07:28 AM | #7 |
Here's one solution to consider....when replacing the rear door handle on our BURB/barn doors (and as you mentioned in your post) I too discovered that the lock release actuating rod for the rear door required more length (approximately 1/4" more) than the driver or passenger doors rods required. I disassembled a new right side door handle, removed the actuating rod and welded a rod on to the end of the now disassembled new actuating rod. Cut to length (approximately 1/4" more was added to the rod) and it now works like a champ! Problem solved and we now have a new outside right side door handle on the BURB cargo door!!.....hope this helps.
11-02-2005, 12:52 PM | #8 |
67 is sold
Thanks. It looks like I may have to go that route
