Old 07-10-2002, 10:22 AM   #1
big blue 72
starter problems
gotta continuing probelm with my starter.
when i first start it, evrything is o.k. but if i turn it off and have to start it say, 2 or 3 times in an hour, in seems to turn slower or will sometimes click. brand new battery and cables.
any help guys?
big blue 72 is offline   Reply With Quote
Old 07-10-2002, 10:55 AM   #2
Randy70C-10
Randy70C-10's Avatar
Check your alternator and make sure that all bolts and brackets are tight, and there is good metal to metal ground between the brackets and engine.
Randy70C-10 is offline   Reply With Quote
Old 07-10-2002, 11:04 AM   #3
big blue 72
thanks randy, i will check those. appreciate the help.
Old 07-10-2002, 05:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You have headers on that rig? Sounds like heat soak to me.
Old 07-10-2002, 05:30 PM   #5
pierce
pierce's Avatar
Like Longhornmail said...very common problem with headers and GM starters. Try a heat sheild around the starter for a cheap fix.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 07-10-2002, 05:56 PM   #6
Longhorn Man
After checking your battery connections, (on both ends of both wires) to troubleshoot it, go for a drive at 3 in the afternoon, better yet, the freeway at rush hr. Heat it up real good. Pull into a Quike-Mart or 7-11, and **** it off. Go in and get a bottle of water (large one that is real cold) and get a mtn dew. Get a dew for me while your in there...I'm out.
If it don't start, take the water and dump it on the starter. If it starts, then go to the parts store, get a new starter, and order a heat shield if no one in town has one. I'd wait to install the new starter untill the shield is in hand...otherwise, you'll R-R it twice, and if you do in fact have headers...you won't want to do it twice...trust me.
Or you could just get a life time starter, and see how long untill you get to return it...that's what I'm doing....2 years so far. (knock on wood grain)
Old 07-10-2002, 09:58 PM   #7
chevyman 68 C/10
chevyman 68 C/10's Avatar
Header wrap works great on the starter to reduce heat failure. Maybe you have a buddy that has a little left from wraping his headers.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 07-10-2002, 10:50 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
i got a solenoid heat shield at an auto parts place...
then i took a bunch of aluminum tape
and some fiber glass insulation and made a metalcover blanket deal and just taped it to the starter on the exhaust side...
works great...
before the next road trip however i'm gonna
go to welding supply place and get some welding blanket or such
as well as put a remote solenoid in...
it sucks being stranded in BFE...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-10-2002, 11:48 PM   #9
Longhorn Man
That header wrap will destroy your headers. It cuts the life in 1/2.
For uncoated headers, your looking at a 7 or so year life span.
Not good IMO.
Old 07-11-2002, 01:15 AM   #10
Scrub
Collector of rusty Items
Scrub's Avatar
The truck in the picture to the left has over a million miles on it. I have put about 12 starters on it. I know I need a new one when it does what you just said. Starts fine cold, but drags when hot.
My advice, got to NAPA and get a rebuilt starter.
also, pick up a little two wire rubber electrical disconect. (like the one that new pickups have for trailer lights) cut the small wires that go to your solenoid and splice the disconect in. That way you can do the hard wiring on the bench and just snap the dosconect together under the truck. It makes life much easier.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 07-11-2002, 01:21 AM   #11
Hooter
My other Love
Hooter's Avatar
I used an asbetos mit to wrap my starter works like a hot damn against the headers
MEMBER DISCS UP FRONT CLUB
  • 69 custom camper/cst 10
  • 70 monte carlo 383 stroker with a 700r4
  • 77 fully loaded silverado (back in the backyard for a little while longer)
  • 1980 BMW 320i (back in the garage finally)
  • 1981 f@*d f150 4x4 (Robert red ford) tried to kill me
  • 1972 Honda ct 90 trailbike
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com AC/DC RULES!!!
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-11-2002, 10:18 AM   #12
big blue 72
Thanks for the input gang. Seems like the hot weather brings out the worst in machinery.
Hey , Pierce , where do you live in Cincy? good lookin ol 'horn ya got.
