11-16-2005, 04:06 PM | #1 |
Car Truck Bike Nut
A Mechanic's Tool Glossary
Subject: A Mechanic's Tool Glossary
A Mechanic's Tool Glossary DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted airplane part you were drying. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle. TWEEZERS: A tool for removing wood splinters from the 2X4 you just used. PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog **** off your boot. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway. TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over- tightened 58 years ago by someone at the Tydol station, and neatly rounds off their heads. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50¢ part. HOSE CUTTER: A tool used to cut hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, CDs, DVDs, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need. EXPLETIVE: A handy balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Snow free Florida panhandle, don't miss Indiana winters Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL 68 shortfleet project 94 3500 TD dually so many cars so little time 72 K2 CST 2WD Blazer |
11-16-2005, 04:13 PM | #2 |
Still Green but learning
Re: A Mechanic's Tool Glossary
LOL thats good.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
11-16-2005, 06:00 PM | #3 |
Next!
LOL. Those ARE good!
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
11-16-2005, 06:34 PM | #4 |
What's that funky smell?
You been lurking around my shop at night?
Mighty funny.
Mike S 68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck 3 on the tree, 307, No power brakes or steering Factory Options - HD rear spring and Ammeter/Oil Gauges My truck blog My Car Domain page |
11-16-2005, 06:50 PM | #5 |
Car O'Holic
haha thats awsome!
11-16-2005, 07:11 PM | #6 |
Still drivin' a Rat Rod
LMAO Those are so true
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-16-2005, 08:51 PM | #7 |
its all about the +6 inches
I read that too, it's been in a few magizines.
Although, the #1 use for Vice Grips.... to stop the bleeding. |
11-16-2005, 08:52 PM | #8 |
oops...wrong one
11-16-2005, 09:06 PM | #9 |
Designated A-hole!
I thought that was what duct tape is for. I admire the use of grease to prevent infection.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-16-2005, 09:15 PM | #10 | |
and yes i know i am a red neck
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 C30 flatbed dually 1970 C10 longbed stepside (in pieces) 1976 Dodge Dart 1963 Dodge Dart |
11-16-2005, 09:49 PM | #11 |
Post Whore
haha I was cleaning some old sticker off a window on a car I was detailing and was talking not paying attention and sliced my middle finger so deep the blade went in the inside and you could see it touching the nail, I grabbed a blue shop towel and duck tape made me a bandage and finished detailing that car then did a little work on the truck. I cut the finger at 8 am by dark that night I decided to go to the house and clean up the damage, amazingly the thing had just about healed completely! I put a bandaid and some neosporin and it was good in a couple of days.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
11-16-2005, 10:59 PM | #12 |
Car Truck Bike Nut
LOL, cut my finger on rocker panel area brushing dirt away, sharpass sliver of metal went deep. Lucky me, I have garge in basement, bathroom just off garage, washed it off, lil piece of toilet paper and duct tape, back to work. How many times you try to hold the piece of meal you're drilling only to have it spin on you? Probaably my most common jackass from the list above.
11-16-2005, 11:57 PM | #13 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-17-2005, 12:36 AM | #14 |
Post Whore
Man after rereading those I think just about every non fragile tool in our shop falls into the dammit catagory
11-17-2005, 01:06 AM | #15 |
lol, aint those the truth
-Steve |
11-17-2005, 01:48 AM | #16 |
Gone Fishing
lmfao
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
11-17-2005, 02:21 AM | #17 | |
hmm...
Hell, even the fragile ones get thrown when I get mad enough. Then it's another $80 going to the tool man.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
11-17-2005, 03:26 PM | #18 |
wish i had a garage when i chunk the tools they land in in the pasture i need a metal detector to find them
11-17-2005, 04:29 PM | #19 | |
Post Whore
11-17-2005, 04:37 PM | #20 |
hmm...
well, there are some tools that I simply don't use because I know they could become projectiles - like $300 calipers, etc.
11-17-2005, 06:09 PM | #21 |
Registered loser
Last time I used a Dammit tool, I pegged by buddy in the head with a 1/2 Wrench.
-Nate- There is no replacement for displacement 1996 Buick Riviera 3.8L S/C V6- DD 1973 Chevrolet Cheyenne Super C/10 LWB 454/TH350 |
11-17-2005, 06:32 PM | #22 |
Post Whore
I hit myself with a dammit tool once, taking out a cab mount bolt the one on top in the floor board started spinning so I put a large wrench on the top and put a 3/4 inch impact on the bottom, hit the trigger of the impact before I put my hand on the wrench took a dammit tool upside the head about 1/2 inch above my eye, I was lucky wasn't wearing any safety glasses and just had a HUGE goose egg on my head for about a week, hurt like hell though.
11-17-2005, 06:55 PM | #23 |
i have a 3inch by 3inch hole in the wall at work from a 3lb cross pein damit tool flying across the shop.
11-17-2005, 07:19 PM | #24 |
~Rest In Peace~
super glue is a good bandaid should always have it in tool box or first aid kit
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
11-17-2005, 07:32 PM | #25 | |
Post Whore
