Old 04-16-2002, 09:52 AM   #1
darrel_s
darrel_s's Avatar
Post Brake and Fuel Lines.
Is it better to go ahead and by pre-bent fuel and brake lines, or "in theory" save alot of money by making my own. I've looked into the process and it doesn't look too complicated, but I'd hate to buy all the materials and learn that its a lot tougher to bend and flare tube than it looks. Opinions?
If I'm better off trying it myself, whats the best place to order the stainless steel tubing and tools?
If pre-bent is the way to go, is their anybody that has used the LMC or Inlinetube.com kits and were pleased with the product? Thanks
http://www.forsakenproductions.com/1971_K5
darrel_s is offline   Reply With Quote
Old 04-16-2002, 10:21 AM   #2
JimKshortstep4x4
Smile
We prefer to bend our own lines because it does cost less and we can duplicate the lines with the springs on them like the factory did. I like to do lines and have done
(15) cars/trucks where all lines were replaced. I bought my double flaring tool from Eastwood and it has held up well. I have three benders of various radii and I do a lot of hand shaping as well. Bending 3/16"
and 1/4" lines is pretty easy. Bending 5/16"
and 3/8" lines is tough.
The double flares take some technique and you may have to redo a couple when you start out but it is possible to make them better than the ones on new lines with a little care. I have only made lines from the steel coated lines so I don't have experience with stainless which can be difficult to work with depending on the grade. If you are going to go with stainless, you may want to try flaring a small piece before making a decision.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-16-2002, 11:01 AM   #3
darrel_s
darrel_s's Avatar
Post
Jim. Is stainless just a cosmetic preference or does it really have a longer life than standard coated steel?
I have heard tha stainless can be quite tricky to make flares on. Especially Doubled.
Where do you buy your tube?
Old 04-16-2002, 12:47 PM   #4
JimKshortstep4x4
Smile
Stainless is a better corosion resistant material but the coated material lasts a long time. A lot of the steel brake lines were still functional on the the 30+ year old trucks and that says a lot.
I buy my lines from my local AUTO Value store and I will usually buy the lines that are ready made but close to length and then
cut and flare them for the shorter runs. On the longer runs, (over 5 feet), I order coils of line so as to avoid any couplings.
I don't get my lines from Autozone because of the color, (I like the zinc plating), and theirs are olve drab). NAPA has a good selection, also but they are not very close to me.
If there are protective springs needed I get used stock from the local yard and clean it before painting.
I have never tried to purchase stainless still because I don't see the need for stainless in this application.
Jim
Old 04-16-2002, 12:54 PM   #5
Woody
Post
Hey Jim,
Are you removing the protected springs from old brake lines? Then cleaning & painting them before sliding them onto the new lines?
Woody
'69 Custom-10 Deluxe
Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet
Coming soon 700R4, 350 Crate Engine, Pwr Disks...
Woody is offline   Reply With Quote
Old 04-16-2002, 02:01 PM   #6
guyryan100
guyryan100's Avatar
Post
I am planning to order from inlinetube.com in the next 2 weeks or so. Depending on your time frame, I will be glad to let you know how it turns out.
I am not sure how much $$ I would save if I had to buy the bending / flaring tools . . . that's partly why I'm buying the pre-bent lines.
I'm not going to use stainless, though. I figure the first set worked fine for ~30 years! :-)
guyryan100 is offline   Reply With Quote
Old 04-16-2002, 02:10 PM   #7
darrel_s
darrel_s's Avatar
Post
Guyryan100. Definatly shoot me an email after you get them installed. Thanks
Old 04-16-2002, 07:41 PM   #8
Tim Christian
Tim Christian's Avatar
Thumbs up
I bought the stainless one from Inline Tube they fit prefect I also used there E-brake cables and they were GREAT also!
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
