11-21-2005, 03:18 AM | #1 |
Battery & Battery Tray
After 2 years at the body shop (don't ask!) I got my truck home. The battery was shot and I went looking for a replacement. It seems that "Group 74" batteries are not really common and I believe these are the ones needed for my 72 Blazer. Has anyone has the same problem?
Also, I decided to change my rusty battery tray, but it seems that 3 of the bolts require me to remove the radiator. Is this necessary to replace the tray? Thanks
"If you choose not to decide . . . you still have made a choice." |
11-21-2005, 10:54 AM | #2 |
Back in the sticks
Re: Battery & Battery Tray
If you can loosen up the radiator mounts on the top and slide the radiator to the side, you can get to the bolts. I just run a regular top mount battery from Autozone in all of my vehicles. There are probably better ones out there, but they warranty them and they are fairly cheap. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
11-21-2005, 10:02 PM | #3 |
I have a group 25 in mine, works like a champ. Ditto on the instructions above, that's how I replaced mine a couple months back.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
11-21-2005, 11:41 PM | #4 |
PROJECT 7DEUCE
I got an optima in my blazer fits very well..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-22-2005, 03:24 AM | #5 |
Yup, Optima Red Top, perfect fit!!!!!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
11-22-2005, 04:41 AM | #6 |
Red top Optima here too and a new Battery Tray.
I used a universal clamp on top to hold it in place had to modify the long threaded rods but that Battery is in there to stay no more bouncing around. I think thats why my Batterys never lasted more than 18 months.
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html Last edited by HatGuy; 11-22-2005 at 04:41 AM. |
11-23-2005, 01:22 AM | #7 |
I will be battery shopping this week. My Napa battery cranked it's last crank. wont ever take a charge. I switch over to side terminals a while back.
11-23-2005, 09:20 PM | #8 |
I found an AC Delco Group 74 battery on line, but the guy can't ship batteries. I called my local Chevy dealer and they got me the same AC Delco battery for the same price. Thanks for the advice on the battery tray. I will put it in and be ready to go!
If you're interested in a reproduction vintage battery I found those for $285.00 http://www.BatteryCentralMall.com Here's the picture: http://www.batterycentralmall.com/Ba...pt/R89_HC.html
