Old 12-04-2005, 08:08 PM   #1
nu arty boy
nu arty boy's Avatar
FNG in Michigan needs some answers/help
My name is Jason and I inherited my Grandfather's old '86 C-10. I'm actually a Jeep guy (1999 TJ, 2004 KJ) but I couldn't pass on picking up the chevy. It needs some work since it has been sitting outside for the last 5 years and not driven at all.
Long story short, it had the origional 4.3L ripped out and a 305 put in but kept the stock tranny (3speed auto) and radiator. The truck runs, but it seems like it doesn't have any power. Its got Eidelbrock 4bbl carb & intake and borla exaust but no balls...
My question is what kind of tranny would some of you experts recommend replacing the stocker with? TH400? 350? Is the V6 radiator going to work well enough with the 305 or am I going to have to worry about overheating problems?
nu arty boy is offline   Reply With Quote
Old 12-04-2005, 11:14 PM   #2
rollinlow
rollinlow's Avatar
Re: FNG in Michigan needs some answers/help
welcome from tenn and a 700 would be great but a 350 would handle it easily
rollinlow is offline   Reply With Quote
Old 12-05-2005, 01:28 AM   #3
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South MIssissippi. Any tranny in good mechanical condition should stand up to a 305.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-05-2005, 03:34 AM   #4
nu arty boy
There is the question of gearing also. I'm sure that the OE trans is geared to the V6. What are most of you guys running in a 2WD work truck? Ultimately this will become my project/daily driver - I'm not looking to take it to the strip or anything.
Old 12-05-2005, 04:09 PM   #5
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
hey there.The gearing for a V6 would be better since it needs more help to move the truck than a V8 ,try a 200r4
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 12-05-2005, 08:30 PM   #6
bad_burb
bad_burb's Avatar
Welcome to the board from California.
If this truck will become your daily driver and you are planning a tranny swap already, I would use a OD trans like the 700 R4 or the 200 4R that was previously stated.
'73 C-30 3+3 Dually 454/TH400
'74 Fleetside 350/TH350 (SOLD)
'69 Nova 350/TH350 (project FOR SALE)
'63 Nova 305/TH350 3.73 posi (the wife's project)
bad_burb is offline   Reply With Quote
Old 12-28-2005, 12:54 PM   #7
nu arty boy
And what is the wheel bolt pattern for this truck?
Old 12-29-2005, 04:09 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Welcome, I will let others who know the later model trucks answer your questions.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-31-2005, 01:13 AM   #9
TrainD5115
North Coast, baby!
TrainD5115's Avatar
If it's a C10 it should have five lug rims. 1/4T = 5 lug
1/4T 4WD = 6 lug
3/4T = 8 lug
Welcome aboard.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-31-2005, 01:43 AM   #10
nu arty boy
I know its 5 lug, but what is the spacing of the bolts? 5x4.5"? 5x 5.5"? 5x5"?
Old 12-31-2005, 02:12 AM   #11
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Your bolt spacing would be 5 on 5.
BTW, I'm partial to 700R4s. The later models are desired more since they have been 'factory'-updated from the earlier offerings.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-31-2005, 03:53 AM   #12
Russell
Professional Grade
Russell's Avatar
Your biggest reason for having no power is that 305 :P
They arn't well suited for a truck If you want power, get a 350
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-31-2005, 12:55 PM   #13
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have an '86 with a 305. Its a slug.
If your truck has a 3 speed automatic, it is probably a TH350 or TH350C (lockup torque converter). There is no need to change it unless you want overdrive.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-01-2006, 03:11 AM   #14
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Welcome to the board. Also look at the rear gearing as well. As others mentioned the 305 is a alright engine for to and from but a 350 would defintely be a step up. But then it may be needed for a new radiator depending on how much core capacity it has.
The TH350 would be a ideal replacement for it but a TH400 would also be good. 700r4 with lower gear ratio like 3.73 or larger numerical may be better but depends on what your use of the truck will be.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
