01-07-2006, 12:18 PM | #1 |
96 lumina intermittent overheating??
hey guys my sister has a 96 lumina with the 3.8 and it overheated this fall, and i looked it over, topped of the coolant (it was a little low), and found no problems. a couple months later it did it again and my dad put a new thermostat in for her. now another couple months later, it did it again. what do i look for? why is it so intermittant? no coolant leaks, so is there crap in the radiator clogging it? why only once ever couple months? any advice is appreciated, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
01-07-2006, 01:22 PM | #2 |
67-72 Addict!
Re: 96 lumina intermittent overheating??
Those motors are prone to intake leaks. Did you check to make sure the fans are working?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-07-2006, 05:08 PM | #3 |
~Rest In Peace~
check for codes maybe a sensor is acting up
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
01-07-2006, 06:00 PM | #4 |
Does the gauge go up really quick and then come back down for no apparent reason? If it does, it isnt exactly overheating. The coolant just isnt staying in contact with the sending unit.
That happens alot with the 3 series motors if the cooling system isnt bled properly. Did you use the bleeder valve either near the thermostat housing or the bypass pipe? If not, let it warm up and build pressure, and crack it open to let all the steam out. Hope this helps. -Jeremy
79 Jimmy slammed AKA James Down |
01-07-2006, 06:09 PM | #5 |
Prestige member Old Farts Club
also bad for head gaskets
Hey sombodys gotta do it! |
01-08-2006, 11:31 AM | #6 |
crack up the bleeder vavle and let the air out it happens if the cooling system isn't bled good
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-08-2006, 07:23 PM | #7 |
hey guys thanks for the help. i drove it around today and quite a bit of air came out of the bleeder valve. i never did get the guage past half way to hot though. like i said before it is an intermittent problem, so i guess i will just keep driving it and wait to see if it acts up again. thanks, Ben
