Old 04-18-2002, 11:45 AM   #1
gm4wheel
Post bouncing tach
This morning when I started my truck, the factory tach was bouncing around, it couldnt stay still. I never had this problem before. It remained bouncing for about 15 minutes then slowly regained control. Is this a warning my tach is going out??
Thank you.
gm4wheel is offline   Reply With Quote
Old 04-18-2002, 11:50 AM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
That, or a bad connection somewhere. Maybe you have a bad ground somewhere. The next time it does it, try listening to the radio on AM tuned somewhere between stations. If you have noise that follows your tach bouncing, I'd suspect a bad connection.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
