Old 04-16-2002, 09:06 AM   #1
Alex Hayley
Question AC questions...
It is about that time of the year to get the AC working. Can someone tell me how I would go about pulling a vacumm on the AC system? It has not worked since I got the truck(a couple years ago) so I am figuring I need to evacuate the system. Also, from what I can gather, if I pull a vacumm and hold it for a while you can tell if there is a leak in the system. Am I correct?
Thanks...
Alex Hayley is offline   Reply With Quote
Old 04-16-2002, 09:28 AM   #2
Hutch
Hutch's Avatar
Post
YES,
You would use a vacuum pump, Most shops that do auto repair have one. After pulling a vacuum I understand that you need to let it sit for at least 30 min to see if there is any leakage.
You need to be careful when working with R-12
there are alot of procedures that the EPA requires which just seem to make the repair prices go up.
I would think that you are on the right track
Be sure and get the system as tight as possible before investing in all the expendable parts(dryer,expansion valve,etc.)
John Hutchison
Grapevine,Texas
76051
71 1/2 ton swb 307 pg
69 Jaguar XK-E 4.2 Roadster
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-16-2002, 09:37 AM   #3
Frank_Zeller
Frank_Zeller's Avatar
Post
If you have access to a Nitrogen tank with pressure regulator you can rig it up to pressurize the system to about 50 psi then use a liquid with soap the shows bubbles from the leaks on all the lines and components.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 04-16-2002, 09:39 AM   #4
Alex Hayley
Post
If I was going to do this work myself where might I find a vacumm pump? I actually have two vehicle(72 chev and 97 VW) with the AC not working so I figure I will learn how to do it myself and save some money.
Old 04-16-2002, 11:00 AM   #5
Hutch
Hutch's Avatar
Post
Try this,
Looks cheap enough who knows it might work for you http://ww2.harborfreight.com/cpi/cta...temnumber=3952
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 04-16-2002, 11:21 AM   #6
HuggerCST
HuggerCST's Avatar
Post
You will need another set of guages for the '97 VW. I believe all vehicles '94 and newer use R-134, which takes special guages. You can use the same vac. pump though.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-16-2002, 01:08 PM   #7
Frank_Zeller
Post
these guys also sell the 134A to R12 gauge adapters and new gauges.
http://www.duracoolusa.com/
Austin-Texas
Old 04-16-2002, 03:13 PM   #8
Vince M
Vince M's Avatar
Post
Alex,
I'm going through exactly the same thing myself. I've been looking at swap meets and found a set of used gauges. Check out eBay for a pump. There's a bunch of them there. Robinair makes some stuff for AC service. I've gone to their web site and learned a few things. There's other makes out there also which look to be pretty good. eBay will give you a good idea on market prices.
Orlando,FL
72 Chevy 4x4 3/4T CustomCamper w/SB 406
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 04-17-2002, 07:56 AM   #9
Alex Hayley
Post
Vince,
In the event that you check this thread again, it looks like the vacumm pump on ebay is the same as mentioned above(http://ww2.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=3952
) only the one at harbour freight is less money. At least that is what is looks like.
Alex
Old 04-17-2002, 08:18 AM   #10
ebfabman
Post
Guys, AC pumps and gauge sets are like batteries and tires, not something you really want to buy used.
Been a cerified auto air tech for about 20 years and seen lots of vac pumps that didn't work and lots of gauge sets that looked ok but didn't work properly or not at all.
ONLY BUY USED AC TOOLS IF YOU KNOW THE SOURCE!
ebfabman is offline   Reply With Quote
Old 04-17-2002, 11:56 AM   #11
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Post
Alex Hayley is correct.
Don't buy the Central Pnumatic Air Vacuum Pump from Ebay.
Harbor freight has them for $9.99 and actually there on sale for $8.99 now
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 04-17-2002, 07:40 PM   #12
Vince M
Vince M's Avatar
Post
ebfabman has some good advice. Be carefull buying used stuff. The vacuum pumps I was looking at were a lot more than $8.99.
At swap meets it easy to find an outlet and plug 'em in before buying them but eBay etc.. makes that kind of hard to do. I take the price into consideration when buying used.
I've seen an old refigeration compressor used as a vacuum pump if you have access to an old refrigerator and don't mind gutting it. Of course that would release Freon into the atmosphere..not such a good idea these days.
Orlando,FL
Old 04-18-2002, 12:58 PM   #13
DennyB
DennyB's Avatar
Post
Vince,
That is a great idea!
I've got an old compressor that the pump is shot but motor and tank is good.
and an old refrigerator that has a good compressor.
I have to get the freon removed to dispose it anyway.
Put the 2 together and I have a A/C vacuum pump and a power brake bleeder!
Thanks for the idea!!
Denny
I.M.O.M,W,J&C
Patriot Guard Rider
