Got a 1/2 ton 2wd frame to use but 2 center leaves are broke on drivers side.top leaf and bottom leaf are fine. Will leafs from a 3/4 ton interchange and if so which leaves do I use as I think it has six.
Collector of rusty Items
I just left the main one in and added the rest in. You might pick through the 3/4 ones and try to match the 1/2 ton pack for length.
Springs is springs. ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
Solver, they should interchange 69-72 at lkeast if not more years, up to 73 though, 2.5" width i believe, thats what is on the 72 C10 and the 72 4x4 K5 i have around, im sure 3/4 ton are same thing
good luck ------------------ Randy- Lincoln, IL r68c30@hotmail.com -71 C-10 350/CH465/3.07 -84 Z28 Camaro 5.0L 700R4, 3.73 -84 Firebird SE 2.8L T-5 -82 Firebird 350 4bolt (TBL)/TH350 buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
